I tried the eBay MX50 DIY Kit, Class AB 100W+100W; Worked but problem
It's nice to have the designer's input, thank you.
Which is the best sounding amplifier, the MX50 or the MX50X2? I bought the MX50X2 because of its 4 output devices.
MX50X2 originated in MUSICAL FIDLITY MF-XA50. Is a very distinctive, good circuit.
MX50 circuit similar, but output using low distortion CFP circuit.
The two are very stable, and very convenient production.
Just wondering if it's possible to reduce the gain of this amp, the rest of my kit has to have the gain turned right down when driving it to produce reasonable listening levels.
Change the value of R7 (as in the post 39 schematic) to 27k. If it's still too loud, up the value of R9 to 1k2 or 1k5 or 1k8 or whatever works for you.
Hello. I am very bad speak english, i am from Russia. bought the same kit. one channel is working fine, and when you turn on the second channel, the quiescent current in the arm + shows 0.82 A and is not regulated. may suggest what could be the problem. Thanks in advance.
Have you adjusted the bias potentiometer? If you have tried already and there was no effect on the current, check the pot resistance varies on a DVM.
MX50 100W + 100W
I built the same amp - however the modules I bought off Ebay were pre built and tested.
I'm not sure if the circuit diagram I posted is correct for the modules I have - but it was the one published on the auction page.
Details here is anyone is interested.
Mine is running at a lower power, as I'm using a 35-0-35 Vdc supply.
Any verdict on sound quality yet?
It sounds absolutely superb.
I currently have access to several power amps, Harman Kardon HK870, NAD2200 (very modified),Rotel 850 - and it beats them all, hands down.
It's very detailed, and the bass is simply superb too.
Source is Marantz CD17 (modified), Cambridge Azure DAC Magic, Ebay "Big DAC", and Logitech Squeezebox Duet.
Decrease gain
About MX50-SE(v7), I have a question, please:
I want to decrease the gain to 20 ~ 25 times for use in multi amplification for treble and mid range. What are the values ​​and the resistors need to change?
thank you
you tell me how to set up their amps? the picture you need using the variable resistor to set the voltage 550mV? I did that but little bass in the sound has to turn the equalizer in the player. Transistors may not work properly? on hearing the sound of a very high quality, but a little bass.Nutrition 47 - 0 - 47.
you tell me how to set up their amps? the picture you need using the variable resistor to set the voltage 550mV? I did that but little bass in the sound has to turn the equalizer in the player. Transistors may not work properly? on hearing the sound of a very high quality, but a little bass. Nutrition 47 - 0 - 47
Moral of the story... don't underestimate the need for on-board filter and bypass capacitors on the rails.
If you look at the original Musical Fidelity pcb that LJM posted you can see that PSU is only an inch or two away from the output transistors. With PSU so close one may not need bypass caps for absolutely stable performance. But LJM made clone board without PSU and many constructors will place PSU at greater distance from the amp board so it would be highly desirable to have bypass caps onboard near output transistors. It would probably be the easiest to place footprint for 100nF/100V SMD polyester caps on the bottom side of pcb near output transistors, if LJM decide to make some new version of the pcb.
