Old 29th January 2011, 05:29 PM   #1
moschfet's Avatar
Default Gimos50 - a robust guitaramp with IRF240/IRFP9240
Hello people,
this is my first projekt, that I post here. I want to build a very robust guitaramp. In the past I have built some hifi amplifier, so I am not a bloody beginner
The headline says it. I plan to use irfp240/9240 Mosfets for a 50watt Amp. And I like to give my projekts names, so I call it 'Gimos50'.
There are some conditions for Gimos50:
- it should be oversized to have some reserves
- soft clipping
- stable work
With LT-Spice is this schematic caused. Gimos50 has a very low open-loop-gain. There are high lokal currentfeedback in the voltagegain. The negative-feedback-factor is very week. The result is a stable circuit, it don't need great frequency compensation.
The z-diodes in the negative feedback are limit the output voltage. About 25V should be enough for 50watt at 8ohm.
The overcurrent protection limit the output current to 2A per Mosfet. There should be enough reserves for continuous load.
Old 29th January 2011, 08:42 PM   #2
moschfet's Avatar
i have made a FFT with LT-Spice. This pictures shows 1kHz, 1watt and 50watt:
This simulation shows the cut-off-behavior:
Old 29th January 2011, 10:47 PM   #3
nigelwright7557's Avatar
You schematic hasnt been uploaded.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 29th January 2011, 11:59 PM   #4
moschfet's Avatar
strange
I can see it.
This is the url:
http://www.diyaudio.com/forums/galle...62/Gimos50.jpg
Old 30th January 2011, 12:02 AM   #5
Originally Posted by moschfet View Post
strange
I can see it.
This is the url:
I get webpage not found.
Old 30th January 2011, 12:10 AM   #6
I get "link is broken" It worked a few hours ago though.
Old 30th January 2011, 12:22 AM   #7
moschfet's Avatar
Ok, I uploaded it on other sever :
Hostarea Gimos50.jpg – Kostenloses Bilder Hosting
An I hope it work...
edit: it can't be true
Old 31st January 2011, 02:08 PM   #8
moschfet's Avatar
This is the layout of the first board(100x160mm). I work with kicad, it is open source and I like it.
The space is not filled with components, so I consider to shrink it.
Old 31st January 2011, 02:12 PM   #9
aman khalsa's Avatar
nice work bro...i like it.
thank u...
Old 1st February 2011, 01:51 AM   #10
moschfet's Avatar
The new layout has not gotten smaller, but better.
The key tracks are shorter.
There are fewer bridges.
The differential amplifier has now a thermal coupling.
To protect the acid I have closed the open areas as much as possible.
Radio to guitaramp conversion hum problem Krille Tubes / Valves 6 12th August 2010 06:54 PM
new ampli with IRF240 xcicc Solid State 23 29th May 2009 05:49 AM
Robust Power Supply PCB suited to hi-quality amplifiers RyanW Solid State 58 17th April 2008 12:34 PM
Need helps with building guitaramp hoangduongo Instruments and Amps 1 22nd February 2008 08:23 PM
mosfet 450w irf240 / irfp9240 amp help aletheian Solid State 5 29th August 2005 03:20 AM
Page generated in 0.38958 seconds (23.81% PHP - 76.19% MySQL) with 10 queries
