Old 28th January 2011, 03:00 PM   #1
Default Looking for 4 channel x 100w RMS amp schema
Hey ther...i'm new here....I'm a student in electrical engineering at college....i'm looking for a schema to do a 4 channel x 100w RMS for my car speaker....2 stereo IN...and 4 OUT
THANKS
Anthony
Old 28th January 2011, 03:59 PM   #2
I guess your not allowed to just go an buy a 4x100w caramp.
Maybe the quasi amp for beginners by apex audio x4 would suffice.
Old 28th January 2011, 04:06 PM   #3
No...we want to say...I DIT IT MY SELF
Old 28th January 2011, 04:55 PM   #4
But if we help you then you won't have done it yourself........
Old 28th January 2011, 05:00 PM   #5
I don't need to design the schema...I need to BUILD the amp!
Old 28th January 2011, 06:07 PM   #6
AndrewT is online now AndrewT  Scotland
What supply voltage does it have to run from?
What impedance are the speakers?
Do they need to be real Watts of output or would any old PMPO power output do?
regards Andrew T.
Old 28th January 2011, 06:10 PM   #7
Real watts !!
4 ohms speaker
12V supply as it will be in a car !
Old 28th January 2011, 06:19 PM   #8
A 12Vdc supply will allow a maximum of ~+-5Vpk into your 4ohm load.
This is equivalent to ~3W into 4ohm.
If you build a balanced or bridged amplifier using the 12Vdc supply you may get 6W into 2ohm from one half of the amplifier. When bridged/balanced you can expect 12W into 4ohm speaker.
You now need 8channels of amplification each capable of 6W into 2ohms (reactive speaker) to get 4channels of 12W maximum power output.
Do you see a problem?
Maybe the purpose of the project is to recognise that the target is impossible to attain from a 12Vdc supply.
Guess where your research will take you next?
regards Andrew T.
Old 28th January 2011, 06:21 PM   #9
Yeah I know...but its 12V from my car battery...but there will be a powersupply to get higher voltage input !....
Old 28th January 2011, 06:25 PM   #10
ostripper's Avatar
Originally Posted by packetrace View Post
Real watts !!
4 ohms speaker
For real watts , you need a switching power supply (12V to +/- 40-50V).. this is typical of most analog OEM multichannel "blasters". The amps are typically LIN topology 1 or 2 output pair pair class AB.
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
2.1 Channel Car amplifier 100W,200W using Class D avi198617 Car Audio 7 23rd October 2010 09:30 PM
FS: Carver M1.5T 600w rms 8 ohm/channel Bent Swap Meet 0 3rd June 2008 02:49 PM
2-channel parallel 100W GC using LM3886 scone Chip Amps 30 28th August 2007 02:19 AM
Need help fo 100w+per channel stereo chip amp mlaroche Chip Amps 14 12th December 2006 12:20 AM
1800W RMS into 4 ohms per channel Kilowatt Solid State 6 6th June 2004 07:15 PM
Page generated in 0.11569 seconds (74.74% PHP - 25.26% MySQL) with 11 queries
