Old 28th January 2011, 04:48 AM   #1
Default Phase Linear 700 resistors
The right channel of my 700 is going gangbusters but the left is a tad lower. After recap I ordered a driver board transistor kit but perhaps the solid appearance of my carbon comp resistors is deceiving me. The 7.5k's on the left are baking hot. My problem is wattage of all resistors. Schematic says marked resistor is one watt and who knows about the small ones.
Old 28th January 2011, 05:46 AM   #2
Typical schematics may say something like 'All resistors 1/2 Watt unless noted' or 'All capacitors 0.1uF unless noted'. Be very suspicious of carbon resistors running 'baking hot'. Very often they change values downward until something fails.
Old 28th January 2011, 05:49 PM   #3
wg_ski is offline wg_ski  United States
The small ones are 1/2 watt - you can tell by the size. All 1/2 watt from that vintage are that size - modern ones are a lot smaller.
The 1 watters on those boards do get baking hot in normal operation. The PCB cooks over time, the traces can peel up form the board, and the solder joints can fail. Replace with a *2 watt* metal oxide type and space it up from the board so it can cool. And beef up the PCB traces with a piece of a resistor lead and fresh solder.
Old 29th January 2011, 12:23 AM   #4
Oh Hell yes! thanks!
Old 29th January 2011, 10:53 AM   #5
Default Is this right?
So the choice for the 1/2 watters was 9 cents for xicon and 32 cents each for koa. Carbon film through hole. Am I done yet? I got the koa
Old 16th February 2011, 03:21 AM   #6
Default offset trim pots
These 100k and 50k trim pots are confusing to replace. Can anyone point me in even an aproximate right direction?
Phase Linear 700 series II restoration P.L.F. Solid State 50 30th October 2011 04:08 PM
Phase Linear 700 Series Two recapping releone71 Solid State 4 12th March 2010 07:32 PM
Phase Linear 700 question ? thermal runaway Solid State 3 12th April 2009 08:33 AM
Phase Linear Model 700 Gibbi Solid State 123 9th May 2007 04:25 PM
Phase Linear 700 eats sppeakers chuckg Analog Line Level 4 12th August 2005 06:17 PM
Page generated in 0.10722 seconds (65.45% PHP - 34.55% MySQL) with 11 queries
