I recently bought a second hand TEchnics SA-AX720 receiver and was wondering if by any chance i can connect a Yamaha external graphic equalizer such as GE-70. I hereby attach a picture of the rear panel of the receiver for the proper assesment. I would not like to spend money on a graphic eq if the amp is not able to accept this eq.
Looking for precise advice. |
#2 |
You can hook it up to either the TAPE loop or VCR loop. REC OUT to the input of the EQ and PLAY IN to the output of the EQ. Both should work fine unless there is something "special" about the VCR loop.
Craig |
#3 |
If i connect it to the tape input will i be able to equalize the frequencies of the radio, cd and phono?? my set up does not include a tape deck. i will only be using a turntable connected at the phono input, and a cd player at the cd input.
It does not make sense since it will only equalize when the receiver is set on tape and not on phono or cd. |
#4 |
When you record something from any of the inputs, tuner, phono, or whatever it all goes out to the the REC OUT jacks then through the EQ and back into the receiver through the PLAY IN jacks. Hook it up the way I explained and push the tape button and play whatever source you want to. Try it, all inputs will be EQ'd.
Craig |
#5 | |
This means i dont necessary have to have the selector switch on the tape mode to hear the signal eqd? I connect it this way and when i switch the selector switch to phono, it will also be eqd as desired?
#6 | |
Bummer. I can't see how to add an insert without resorting to soldering iron. |
#7 | |
#8 | |
#9 |
Never dreamed there would be two tape loops that aren't loops. The only other way would be just to hook it up between the source, CD for example, and the CD input. Not very convenient but EQ'd, but no soldering iron either.
Craig |
| A trick for connecting Graphic EQ to Amp | gmphadte | Solid State | 1 | 8th April 2010 07:33 AM |
| Help with Technics SA-5370K receiver | stex | Solid State | 4 | 26th July 2007 07:13 AM |
| Connecting EQ to Surround Receiver | sdclc126 | Multi-Way | 7 | 28th February 2005 06:15 PM |
| Vintage Technics SA-500 receiver... | meelis_l | Analogue Source | 3 | 2nd February 2005 06:49 AM |
| Receiver Technics SA-AX720 | george88 | Chip Amps | 2 | 17th October 2004 06:45 AM |
| Page generated in 0.26989 seconds (36.64% PHP - 63.36% MySQL) with 11 queries |
