I've read that an effective volume control that preserves sound quality is to attenuate the transformer. The EE student inside me is very curious ... can anyone provide example schematics, theory, etc? Have I misread, and it is not possible to attenuate a transformer? This is for a gainclone style amplifier by the way. I can't really think of how to do this, and I've had no luck searching.
Any help is appreciated... |
#2 |
No help?
#3 | |
Hi, This isn't good idea. I saw some poor quality audio clippers application with OP-amps and variable +/- rails, but this isn't HIFI definitely. (Analogue AM transmitters uses this approach in modulation circuitry) Regards |
#4 |
diyAudio Moderator Emeritus
I think you mis-read...
#5 |
Hi there,
I think you may be getting confused with transformer volume controls TVC's. These are multi tapped signal transformers used as volume controls. A search of the audio asylum archives www.audioasylum.com over the past couple of years should bring up lots of information. regards Khush |
#6 |
You can test this simply by plugging any amp into a Variac. I think you will find that it has little if any effect on volume until you bring it down the point at which clipping sets in where upon distortion goes through the roof.
Either you misunderstodd the advice or you need to find a better source for advice. |
#7 |
Thank you sirs, I will look for a better volume control method now
#8 | |
Thinking of voltage regulating circuits, the waveform you get from a ferroresonant transformer is also not symmetrical. |
#9 |
"Actually, the waveform you get from a Variac may or may not be a perfectly symmetrical sinewave -- that is, the wave in the second quadrant may have a different shape from that of the first quadrant -- it may be somewhat distorted.
Thinking of voltage regulating circuits, the waveform you get from a ferroresonant transformer is also not symmetrical." I was thinking in terns of clipping distortion at the amplifier output. The Variac was just a way to conviently control the DC at the rails. The effect, if any, of the waveform from the Variac would depend on the success of the power supply design in filtering ripple, noise and so on and on the PSRR of the amp itself. The orginal post, If I read it right, seemed to be talking about controlling volume by attenuating the tranformer output and hence the rails. |
#10 | |||
diyAudio Senior Member
Ciao,
Frank |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 06:10 PM |
| attenuating...... | Lostcause | Everything Else | 6 | 27th November 2008 03:16 PM |
| Attenuating input gain on X amp? | jeffjazz | Pass Labs | 3 | 7th June 2007 03:39 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 02:30 PM |
| Multiple drivers in same enclosure & resistors for attenuating tweeters | bm_mode | Multi-Way | 4 | 14th October 2001 03:21 PM |
| Page generated in 0.14813 seconds (70.44% PHP - 29.56% MySQL) with 10 queries |
