MEMDIST POWER AMP + JC + TMC - help to set up
Old 25th January 2011, 09:25 AM   #1
padamiecki is offline padamiecki  Poland
Lightbulb MEMDIST POWER AMP + JC + TMC - help to set up
I was hot after reading about headamp from peufeu Memory Distortion Philosophies - Part 8 : More tests
and wanted to build higher power version for LS driving.
Please look at the schematic,
I added JC-like coupling within the mirror and VAS
then I wanted use TMC like gnfb correction like Edmond Stuart proposed Bob Cordell Interview: Negative Feedback
and got this.
Please help to adjust the values/other parameters to obtain the amp possible for working,
I believe that the combination of memdist/TMC correction might give something better that "Lavardin" sound.
Additional explain: I hate global nfb and believe that that solution in most cases spoils the sound,
however
with you help
will this be good sounding?
regards, Pawel
Old 28th January 2011, 10:07 AM   #2
ok
here are initial settings
and sim results
regards, Pawel
Old 28th January 2011, 10:10 AM   #3
and here clipping
Seems that bad 2nd and 3rd harmonics are from the mistakes in the design.
Please advice how to set it more symmetric?
regards, Pawel
Old 28th January 2011, 12:56 PM   #4
Unhappy simplified version
again
not too good...
regards, Pawel
Old 31st January 2011, 08:23 AM   #5
it looks like input tripple clips the signal at 4V.
it is linear but clips...
how to improve its headroom?
regards, Pawel
Old 31st January 2011, 09:03 AM   #6
WuYit is offline WuYit  Sweden
Banned
maybe you should pay a visit to: Cascoding the folded cascode
That`s a much better topology despite some flaws.
Old 7th December 2011, 12:31 PM   #7
Hi
after some time I designed something like this.
As input fet I am going to use BF245B but did not have the models.
The design seems to be a bit from the oscillations
please suggest how to make it more stable.
regards, Pawel
Old 7th December 2011, 12:34 PM   #8
and asc file for ltspice
regards, Pawel
Old 10th January 2014, 09:38 AM   #9
Thumbs up rewarming memdist power
Hi
after some play with LTSpice I found that this time it is working.
Close to full power has very low thd and nice descending harmonics distribution @~110mA idle.
The circuit has the potential, maybe I will build it someday = needs 2SK170 or other 50V DC device instead of BF245B which is only up to 30V (only for simulations).
TMC nice lowered the thd.
asc file attached for play & fun
regards, Pawel
MEMDIST POWER AMP + JC + TMC - help to set upHide this!Advertise here!
Help Set-up Kenwood KAC-1020 Power Amp ianben2406 Solid State 0 8th March 2010 03:22 AM
What to do with TMC tube radio gear? diamondsouled Tubes / Valves 4 31st March 2009 01:30 PM
What is the different, F5 & JC-3 ? thomasfw Pass Labs 0 16th February 2009 01:42 PM
JC-3 class-a power amp millwood Solid State 20 9th January 2004 08:32 AM
Copyright ©1999-2017 diyAudio
