Old 23rd January 2011, 05:20 AM   #1
Hodgie is offline Hodgie  Australia
Default 5-pin DIN to RCA conversion?
Hi all,
I suspect this has been asked before, but I couldn't find a thread that exactly answered the question, so here goes.
I have an older Philips FM tuner in nice timber case - model 22GH927 - only lightweight but fits nicely witha similar timber cased Phodis amp I have just cleaned up.
Issue is, Philips comes with 5-pin DIN cable, whilst the amp takes RCA plugs.
Is it feasible to cut the end off the DIN cable, and re-wire one end to RCA plugs?
If yes, what should I look for when I do cut the cable (I'm assuming I will see 5 wires rather than 2?) and how can I make sure I get both channels connected correctly to the RCAs?
Final question - is it worth doing this at all? I can buy a 5-pin DIN cable that terminates in 4 RCA plugs - I assume this will work OK if I only use 2 of the RCA plugs?
ANy advice appreciated.
Hodgie
Old 23rd January 2011, 10:31 AM   #2
Hi Hodgie,
Have a look at this - hope it helps:
5 pin DIN plug to 2 x RCA plugs sockets ground
Karsten
Old 25th January 2011, 06:50 AM   #3
Thanks Karsten - that's exactly what I'm looking for, and I was able to get one locally ....at a real bricks-and-mortar, staffed-by-real people, stock-on-the-shelf electronics store in the next town!
Many thanks, Hodgie
8 pin din for kenwood WHEELS Car Audio 7 21st February 2012 05:12 PM
How to pair the RCA to 5 Pin DIN? jeremysee Parts 1 15th March 2010 08:44 PM
Alpine DIN to RCA conversion for older EQ's 3015. tomtomjr Car Audio 0 28th April 2009 09:22 AM
DIY Interconnect: 5 pin DIN to RCA Coober Everything Else 7 11th July 2008 03:04 PM
5 pin din to rca how to. saltyreefguy Parts 1 10th June 2006 10:12 PM
Page generated in 0.06593 seconds (79.78% PHP - 20.22% MySQL) with 10 queries
