Old 22nd January 2011, 08:34 PM   #1
Default Proper KSA-50 bias setting???
With out wading through all 10 gazillion posts in the KSA-50 thread can someone tell me the proper bias setting for a KSA-50 with three sets of OP decvices? I had to repair mine due to a slight DC imbalance that existed... found a pre-driver that was way out of spec. and even the DC balance adjustment could not compensate for it. I replaced both predrivers with a matched pair and now it is spot on again. At the present I am measuring ~360mv across the emitter resistors on both channels. Is this correct, or good enough for now? I normally like to do bias by using the distortion analyzer but moine is not set up at the moment and although that works well for class AB amplifiers the distortion analyzer method may not work as well for this amp...
Thanks!
Mark
Old 22nd January 2011, 09:03 PM   #2
pinkmouse's Avatar
Mark, mine runs at 300mV, but I don't push the levels.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 23rd January 2011, 12:03 AM   #3
I donno Al, That does seem a tad on the low side. Krell originally set them to 620mv if you had 4 devices with .68 ohm resistors. I had the program K-Amps wrote to calculate it based on the number of OP devices. Ijust have to find it. We may both be running in class AB at the moment...
Mark
Old 23rd January 2011, 12:08 AM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 23rd January 2011, 01:08 AM   #5
Thanks for that file Zen! Accorsing to the calculator I need to be at 400mv across the .68 ohm emitter resistors to get 50 watts class A out of this amp... Now... do I have .68 ohm resistirs in there? Guess I best take the cover back off and see...
3 Pairs
39 volts
0.68 ohms
400 mv
588.2 mA
8 ohms
0.588 Amps
1.76 Amps
3.53 Amps
137.6 Watts
22.9 watts
99.7 Watts peak
49.8 Watts RMS
36.20 %
76.04 Watts RMS
80 %
Old 23rd January 2011, 04:46 AM   #6
The one and only
Nelson Pass's Avatar
50 watts into 8 is 100 watts peak.
I^2R=100 watts pk
I^2 = 12.5
I= 3.53A pk
I/2 = 1.75 A idle
1.76/3 = .586 A per device idle current
across 0.68 = .399V
looks like your just on it.
Old 25th January 2011, 08:47 PM   #7
Thanks Nelson for confirming that! I appreciate your input on this. I have at present set the bias to 360 mv since my heat sinking is limited on this amp. I have two 120 volt fans wired in series and this keep the sinks at a comfortable temperature. If I go up to 400mv I will have to re-wire the fans in parallel and put up with the noise. Perhaps some sort of thermostatically controled variable speed cooling system is in order for this...
Thanks all!
Mark
Old 25th January 2011, 09:07 PM   #8
pinkmouse's Avatar
Originally Posted by Mark Allen View Post
...Perhaps some sort of thermostatically controled variable speed cooling system is in order for this...
I had one of those.Then I realised that the fans run faster with quiet albums, (Class A - Doh!!), So now I just listen to noisy stuff with it.
Al
Setting Bias kptseng Solid State 9 8th March 2008 01:56 AM
Setting Offset - Proper setup Zero Cool Solid State 12 13th January 2007 02:32 PM
bias setting ben goh Solid State 8 14th August 2006 04:26 PM
Krell KSA 50 nicolas888 Solid State 5 20th April 2006 04:38 PM
ksa-50 MikeW Solid State 34 14th September 2005 04:27 AM
Page generated in 0.11394 seconds (67.67% PHP - 32.33% MySQL) with 11 queries
