Old 21st January 2011, 02:39 PM   #1
Default Cascode input and VAS amplifier design, will it work :)
12 years ago I build an bipolar version of the Elektor Electronics Cresendo amplifier, and it sounded great. This design used a Cascode VAS, which I think was the main reason for good THD performance for this amp.
Now I have made a new design, which is based on the Cresendo input stage, and Cascode VAS. The new thing I want to try is to use Cascode in the input stage, together with active current mirrors.
Im thinking of using Analog Devices SSM2220 PNP and SSM2212 NPN match transistors for the input stage and the Cascode input stage.
Has anyone experience with the combination of Cascode input stage + current mirrors ?
I have attached a preliminary schematic of my design.
(it may have some errors, as I have not build it yet )
Any feedback is appreaciated !
Flemming Bach
Denmark
Old 22nd January 2011, 01:08 AM   #2
djoffe is offline djoffe  United States
Default A problem...
I believe you won't get a predictable quiescent current in the Q27-Q28-Q29-Q30 stage. You will have two dueling very high gain circuits, for the pull down and pull up...this is a version of the same issue that faces the Randy Slone circuit discussed at length elsewhere on the forum...I fear this is kind of a fatal flaw, without some surgery...
Old 22nd January 2011, 05:41 AM   #3
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Current mirrors at both collector loads of differential will cause instability of idle operating point...................Fatal Mistake.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 22nd January 2011, 07:48 AM   #4
alexcp is offline alexcp  United States
alexcp's Avatar
Bob Cordell in his recent book, Designing Audio Power Amplifiers, descibes a stabilized current mirror - see the attached schematic - which should work with a complementary differential input stage.
Also, a cascode VAS has a high output impedance, so you need a high input impedance output stage. The one shown in your schematic, a simple emitter follower, would overload your VAS and degrade its performance. If you want to stick with BJTs, you'll probably need a triple emitter follower to keep VAS performance high.
Old 22nd January 2011, 10:00 AM   #5
Lazy Cat's Avatar
Because LTP input diferential amp is voltage orientated circuit with high output impedance, it is natural to load it with high impedance interlink amplifying stage in "keep it simple" manner, like mosfet transistor or similar. In this way of solution you have nice transfer from pure voltage to pure current.
Old 22nd January 2011, 11:04 AM   #6
Piersma is offline Piersma  Netherlands
Piersma's Avatar
Default Current mirror loading
Contributions by Glenn Kleinsmidt and fab.
Please take a look:
Lateral mosfet w Normal or Diamond buffer?
My new mini Class A amp.
regards,
Piersma
Old 22nd January 2011, 03:25 PM   #7
Thanks for feedback!
I was also suspicious of the DC behavior of the current mirror in the LTP.
Looking at Bob Cordellīs circuit in figure 8, on page 9:
http://www.cordellaudio.com/papers/MOSFET_Power_Amp.pdf
I have made a new circuit based on Bobīs design.
I think Bobīs explain how it works very well, so I wont repeat it here.
Any comments about using this concept ?
Is the Diodes (D2 and D3) in Bobīs design a good thing to have ?
To Alexcp: Yes you are right, my circuits needs some extra emitter follower so the VAS is not loaded.
BR
Flemming Bach
Old 23rd January 2011, 11:22 AM   #8
I found that the Technics SEA3 amplifier, does use a current mirror in the LTP inputstage, which also happens to be connected to a Cascode couplede to the JFET input stage. I dont see that they do anything special to bias/balance the upper current mirror. But again they also do not have any source resistors in the JFET input stage, and they use dual transistors which are properbly pretty equal matched.
@Workhorse: Any comments on the current mirror in the LTP, that you mentioned was fatal ?
But Robert Cordells circuit of how to bias the current mirror does seem to a smart trick
BR
Flemming
Old 23rd January 2011, 03:44 PM   #9
The problem has nothing to do with the cascode, it is related to the complementary push-pull second stage which needs some sort of bias arrangement. In the schematic you show there is no complementary push-pull but rather a differential second stage (some call this push-pull as well, but its surely not complementary).
Samuel
My folded-cascode VAS linearity investigation GK Solid State 96 19th July 2010 10:01 PM
RMI-FC100 MKII, single ended folded cascode VAS roender Solid State 27 9th July 2010 10:56 PM
Amplifier with 220 input voltage, will it work in US? usmcjlp Solid State 5 15th April 2010 06:19 AM
Cascode VAS miller compensation Rafael L Solid State 9 5th March 2009 01:06 AM
Cascode VAS biasing ? sam9 Solid State 8 25th June 2004 10:11 PM
Page generated in 0.12924 seconds (72.77% PHP - 27.23% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
