Parallel G Clones
Parallel G Clones
Old 25th July 2003, 12:32 AM   #1
lawbadman is offline lawbadman  Jamaica
lawbadman's Avatar
Question Parallel G Clones
I'v got a real simple question.
Will the circuit below work, and what is the a maximum number of chips that can be added (power suppy allowing)?
It should be able to drive 4ohm speakers without problems, right?
Old 25th July 2003, 12:40 AM   #2
Elkaid is offline Elkaid  Canada
Elkaid's Avatar
Send a message via MSN to Elkaid
Paralleling chips doesn't really increase power. However, when chips are paralleled, they'll share the load and you'll be able to drive more easily low impedance speakers.
By example, when 2 chips are paralleled to drive 4 ohms speakers, each of them will "think" that an 8 ohms speaker is connected.
If you want more power, try the Bridged + Paralleled schematic.
Hope this helps !
Old 25th July 2003, 12:46 AM   #3
lawbadman's Avatar
Thanks for the repy Elkaid.
By paralleling the chips I want to get about 100watts at 4ohms. I want to avoid bridging because I will be using a 4 ohm speaker.
Will paralleling solve the problem?
Old 25th July 2003, 01:34 AM   #4
Elkaid's Avatar
I can't guarantee you that you'll get 100 Watts (depending of your IC) but I'm certain that you'll have no problems driving 4 ohms load.
By the way, the schematic you posted is very similar to the one provided by National Semiconductors in their application note :
http://www.national.com/an/AN/AN-1192.pdf
Take a look at the schematic "PA-100" (Parallel, 100Watts)
If I'm correct, the schematic you posted is based on the Bridged + Parallel configuration found on this forum right ?
In the application Note, you'll find several combinations such as :
BR-100 (Bridged 100W)
PA-100 (Paralleled 100W)
BPA-200 (Bridge + Parallel 200W)
You have the choice !
Parallel G ClonesHide this!Advertise here!
Beolab 5 clones!!!!! legendaryfrog Multi-Way 72 16th April 2013 01:31 AM
KEF clones nuconz Multi-Way 3 11th September 2006 05:28 AM
FS: A2 clones jrsun Swap Meet 5 7th March 2006 03:29 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 08:12 PM
my proac clones... Jadde Multi-Way 8 10th February 2003 09:51 PM
Copyright ©1999-2017 diyAudio
