Old 21st January 2011, 01:38 AM   #1
Default irf510/9510 or irf530/9530
I want an amplifier, and now candidates are irf510/9510, irf530/9530, one is the capacitor current is also small, but small, one large capacitor current is also large, with tl072q driver, who can give me advice?
Old 22nd January 2011, 07:21 AM   #2
Sadly,no one answer to me?
Old 22nd January 2011, 07:45 AM   #3
Workhorse's Avatar
Send a message via Yahoo to Workhorse
You are lacking many basic concepts, So Sad, that you haven't done your home work yet and came around asking improper questions.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 23rd January 2011, 01:40 AM   #4
CBS240 is offline CBS240  United States
CBS240's Avatar
What pwr into what load Z? would be a good start.
All the trouble I've ever been in started out as fun......
Old 23rd January 2011, 01:17 PM   #5
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
Do you need it with large capacitor and small capacitor, the small capacitor will be around the driver.
Old 23rd January 2011, 05:48 PM   #6
AndrewT is online now AndrewT  Scotland
this might be for a headphone amplifier, or possibly for a line driver.
regards Andrew T.
Old 23rd January 2011, 06:15 PM   #7
winhill2's Avatar
To my mind a common big issue for using mosfets in linear amplifiers is heat conduction, and large-die parts have lower thermal resistance to the heat sink. That would speak for the '530 rather '510 parts. Compare the capacitance, Ciss = 180 or 670pF, that's proportional to area and hence heat conduction. Yep, we see 3.5 vs 1.7 deg-C/watt junction-to-case thermal resistance for the original IR510 vs IR530.
Old 23rd January 2011, 08:00 PM   #8
CBS240's Avatar
Well, in addition to heat another issue is transconductance. 2 Semens is not much for an output device unless they employ higher voltage so as many can be paralelled. A look at the SOA graphs shows you Rds becomes an issue Vds<5V. I supose the 510s could be used for a power amp, but so could a thousand TO-92 J-fets. Without knowing the indended goals of the circuit we are all just generalizing and guessing.
IRF510 and IRF9510 replacement? kacernator Solid State 0 28th April 2009 07:35 PM
Matching IRF530 for a buffer, some results, but I need advice justblair Parts 4 10th July 2008 02:44 AM
ampli mosfet with irf530/9530 ciccio9000 Solid State 17 10th June 2007 10:41 PM
IRF510 Zen amp? Jeb-D. Pass Labs 2 19th July 2006 04:09 AM
Question about IRF510 KT Pass Labs 2 31st August 2005 03:13 AM
Page generated in 0.08843 seconds (75.40% PHP - 24.60% MySQL) with 10 queries
