Ok here is another one...
No visible signs of any fryups or blow outs but when i plug it in it blows the fuse (2a 250v) straight away... Any ideas? |
#2 |
If it uses the typical output IC (TDA7293?), try unplugging the output module and a new fuse. If it doesn't blow probably bad IC. Of the many that I have worked on that's usually the only thing wrong but sometimes the IC wipes out some parts on the main board also.
Craig |
#3 |
I have seen a few of these as craig says it is more than likley the output ic.
also check the mute circuit as i have found that when the ic self destructs it takes out a resistor in the mute circuit.. Mad Mark |
#4 |
Those are the parts on the main board I was thinking of, check the zener diode in the mute circuit. The last amp I repaired it was shorted. If it ends up being the output IC you will have two choices, replacing just the IC or replacing the whole module.
Craig |
#5 |
Hmmmmmmmmmm....
This is doing my head in... am i looking for an obvious burnout? or is it a case of replacing and testing? All solders and connections on the IC's are fine... ill check the zener diode on the mute circuit when i am back in the studio later tonight but as i said... no obvious burnouts or bad connections... Poison Pete |
#6 |
There may not be anything visible, sometimes they go with flames and sometimes they don't. Unplug the module and power it up.
Craig |
#7 | |
#8 |
Cool... Ive got it.
TDA it was... Thanx so much guys! Poison Pete |
| Marshall Valvestate 8080 | kdawg | Instruments and Amps | 10 | 1st May 2012 12:08 AM |
| marshall valvestate 8100 | trai1824 | Solid State | 4 | 27th March 2012 01:36 PM |
| MARSHALL Valvestate VS100r additional mods | screamersusa | Instruments and Amps | 3 | 3rd September 2011 09:16 PM |
| Marshall valvestate 8004 copy | vicelord | Chip Amps | 2 | 9th April 2010 01:34 PM |
| marshall valvestate VS100 schem? | resident | Instruments and Amps | 25 | 25th March 2007 08:59 PM |
| Page generated in 0.12084 seconds (66.03% PHP - 33.97% MySQL) with 10 queries |
