I have at home a couple of exceptional power supply double C-core transformers 650VA 28-0-28 volt AC, four 100mH inductors for DC 5A. two alluminium case whit heatsinks 400W. I would like to build two monoblocks with high power bipolar transistors (or mosfets My speakers are Vertigo Plus project whit Scan Speak illuminator. Impedance is only 3ohm. suggest a schematic or a module with PCB amp top level, thanks! Thanks to all best regards |
#2 |
There are many schematics available on the forum. These transformers must be huge? Keep in mind that when the amp is idle these transformers still draw a lot of current. Monoblocks would be a good choice though! Personally I would go for SE MOSFET driven by an opamp.
#3 | |
--- che la forza sia con te Joda ! |
#4 |
with those parts, I'd be building an aleph 60.
| Any information and schematic about diy Pass Lab XA 200 power amp and X 0.2 pre amp? | jelou | Pass Labs | 17 | 4th December 2011 10:56 PM |
| Need schematic & service manual for Pioneer LD player model CLD-D580 | Assyst1606 | Digital Source | 0 | 9th October 2006 06:16 AM |
| HK 250 power amp tube amp schematic | eddog | Tubes / Valves | 6 | 18th January 2006 03:05 PM |
| TOPWARD MODEL 605 operation manual & Schematic | ku5355 | Tubes / Valves | 0 | 16th December 2005 09:40 AM |
| Multi-room audio system (speakers & Amp question) | dwalter | Multi-Way | 0 | 17th November 2004 07:22 PM |
| Page generated in 0.07833 seconds (67.40% PHP - 32.60% MySQL) with 10 queries |
