Old 17th January 2011, 11:19 PM   #1
opor is offline opor  Thailand
Default Problem with DC Protect
I have build this as per ESP project 33, DC protect circuit. Then I tested the circuit by connect 12VDC supply to AMP terminal .It turn off the relay then I disconnect 12VDC it never turn the relay on.So I power off and leave it untill supply down to 0volt and power it back .It turn the relay no again. Do I have made something wrong?
Old 17th January 2011, 11:32 PM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
In my opinion, that's an overly complicated circuit to perform a relatively simple task. But that's beside the point, I guess...
As far as I can tell, you have two time constants in the system, RN1*CN1 and RN7*CN2. Those time constants are 4.7 seconds each. I would expect this circuit to take several 10's of seconds to reset. In order for this to happen, you need to turn the input voltage to zero (don't just turn it off). If it doesn't reset within, say, 30~60 seconds I'd say something's wrong. It doesn't look like a latching circuit, so it should reset eventually if the input voltage is turned to zero.
The reason for the delay you're seeing if you just disconnect the trigger voltage (marked AMP in the schematic) is that CN1 is then only discharged by the base currents of QN1 and QN2. That's a tiny current, hence CN1 will stay charged for quite a while. By grounding the AMP connection (turning the input voltage to zero) allows CN1 to discharge via RN1.
Even if the circuit requires you to power cycle the amp to reset, that might actually be a feature rather than a bug. You want the amp to turn off and stay off in the event of DC on the output.
~Tom
Old 17th January 2011, 11:52 PM   #3
nigelwright7557's Avatar
I hate those protection circuits with loads of transistors in.
I prefer a PIC based circuit which at least will have quite a bit of inteligence.
I built one with 4 resistors to detect positive and negative transitions.
The PIC also had a 4 second power up delay.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 18th January 2011, 03:11 AM   #4
sregor is offline sregor  United States
Minor point - if you have it hooked up to an amplifier and their is no DC in the output, the amplifier itself will discharge the cap and allow the relay to come back on more quickly. (for your test set up - grounding the AMP pin would simulate a normal functioning amplifier with no DC on the output - just as applying 12 volts was used to simulate a malfunctioning amplifier YMMV.
Steve
Old 18th January 2011, 11:39 AM   #5
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Are you using 6V relays?
We should not dwell on what we do not have, but, instead, be grateful for what we do have!
Old 18th January 2011, 11:45 AM   #6
smartx21's Avatar
BTW, Nigel, are you used to share your designs?
Old 18th January 2011, 12:03 PM   #7
Hi Sregor,
Even I grounding the AMP pin to simulate 0volt DC (power supply is still running),it never turn relay on.
DC offset problem mravlcax Chip Amps 21 30th April 2008 10:08 AM
FS: 2x Elektor EPS 880092 3 (speaker DC protect circuit) oxygene Swap Meet 0 11th December 2007 02:04 PM
DC-Protect Circuitry Fritzell Solid State 96 1st December 2006 04:29 PM
MCU controlled DC Protect for SKA gbyleveldt Solid State 3 12th October 2006 06:55 PM
DC offset problem maxw Chip Amps 38 17th May 2006 02:31 AM
Page generated in 0.10308 seconds (76.66% PHP - 23.34% MySQL) with 11 queries
