According to Sony's manual running the amp in monoblock mode requires 8ohm speakers. That should be no problem for the most ppl, but mine are 4ohm power hungry kappa 100's and the blocks get really hot after an hour listening. The heat isnt a problem to solve if thats the only thing to get things stable for louder listening volumes and for longer times without blowing the amps. So I was wondering if anyone would help me out to tweak the amps impedance lower. Anybody have experience doing this? |
#2 |
The problem is that there are not enough transistors in the output stage to safely cope with the current required for a 4 ohm load. You say your speakers are "power hungry" - this probably means that they quite often dip to 2 ohms.
Adding fans will help a bit, but it will not keep the output transistors safe, and they will eventually go bang. |
#3 | |
#4 |
might be better to mod the speaker/x-over?
rgds jms
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson |
| ta-n80es volume control | Todd Paxton | Solid State | 0 | 8th February 2009 01:51 AM |
| Trends TA 10.1 Tweak-kit 2 and extras... | aquapiranha | Swap Meet | 1 | 13th July 2008 07:01 PM |
| Sony TA-N1 and TA-NR1, how do they sound? | lumanauw | Solid State | 0 | 28th November 2006 01:51 AM |
| Sony TA-N80ES | anonbeat | Solid State | 8 | 30th May 2006 02:13 PM |
| FS: Sony "Esprit" TA-E901 and TA-N901 pre and power amp | MJR | Swap Meet | 1 | 6th December 2003 07:55 PM |
| Page generated in 0.10704 seconds (60.91% PHP - 39.09% MySQL) with 11 queries |
