Old 25th July 2003, 08:15 AM   #11
sajti is offline sajti  Hungary
My amplifier is DC coupled too. But the input stage is designed to be useful for DC servo. The first is paralell 22kohms, and then 2k2+68pF low pass filter, than connect the DC servo with 100kohms, directly to the base of the input LTPs.
I have 10kohms+8.2uF RC filter at the DC servo's output. With this values the maximum offset I can compensate:
290mV. It's enough for most application.
About the ringing: The ringing caused by the instability, due the low phase margin. If You push away the two filter's frequency, there will be large phase margin.
Sajti
Old 25th July 2003, 08:24 AM   #12
Sonny,
sorry, didn't want to spoil the fun. And I am all in favor of building things from scratch where it makes sense to me. In this case, I didn't see the point, so I asked.
Eric
Old 25th July 2003, 08:38 AM   #13
sonnya is online now sonnya  Denmark
sonnya's Avatar
Sajti
Thanks for the tip on the input... have some how been blind for this.
The instability start at 180 degress phase shift.. right... how much phasemarging do you prefer? 60degress? ... I can follow you... just have to make some extra calculation...
Old 25th July 2003, 08:51 AM   #14
sonnya's Avatar
Originally posted by capslock
Sonny,
Eric
Just wanted make a simple gain block every one could build, which could work as a servo, but also with very small changes resistor values could do as much faster opamp.
Old 25th July 2003, 09:18 AM   #15
sonnya's Avatar
I have just digged in my notes....
i can correct up to 10V offset on the output.
at a phase margin of 90degress i have a gainmargin of 1.3
Old 25th July 2003, 09:16 PM   #16
For the phase margin: More is better. If You set the cutoff frequencies same for both filters, You can get 90 degree. It looks enough, but I like more than enough
Sajti
Old 25th July 2003, 09:19 PM   #17
"i can correct up to 10V offset on the output."
It's more than enough, looks OK It would be nice if You can show some schematics
Sajti
Old 26th July 2003, 04:38 PM   #18
sonnya's Avatar
it is soon to come....
When i have made a production PCB i will post a schematic...
I will then be able to offer the PCB, without components,with standard and premium grade components. As a kit or as a finished board.
Sonny
Help with DC Servo for Current Feedback Opamp klewis Chip Amps 31 4th June 2010 06:18 PM
opamp for DC servo lucpes Solid State 10 11th August 2004 10:33 AM
Opamp suggestion for DC-servo in an Alexander amp peranders Solid State 12 19th June 2004 07:18 PM
Adcom gfa-585 dc servo opamp georgehifi Solid State 16 1st November 2003 01:50 AM
Page generated in 0.43398 seconds (24.80% PHP - 75.20% MySQL) with 11 queries
