Old 16th January 2011, 06:25 PM   #1
Default Luxman L-3 crack in speakers at power-on/off
Hello, when my amplifier is switched on or off, a big noise going slightly down is heard in the speakers....
if someone can help ? Thanks. Pierre
Old 17th January 2011, 06:33 PM   #2
I have a Revox B750 that did the same thing. There is a time delay circuit that activates a relay and it is supposed to disconnect the speakers from the amplifier when you switch on or off. This circuit malfunctioned and didn't disconnect. The amplifier would give big pops and moans at turn on or off. Look for something similar.
Ray
Old 17th January 2011, 07:20 PM   #3
Had something similar with a pair of Audiolab Poweramps - turned out to be the protection relays, you could hear them click after approx 5-10secs when switched on but immediately after the Amps were switched on an audible 'crack' was heard through the speakers. Although the relays were energising the contacts were already made (plastic inside relay was broken causing relay contacts to be permanently made) Also another relay in the other poweramp had dirty contacts which caused the mid/bass unit to crackle/cut out at low volumes.
Cheers
Sanken ST-610 Power TO-3 Transistor Replacement for Luxman SQ-503 (SQ503) ?? tiefbassuebertr Solid State 10 1st March 2011 10:28 PM
What causes a tube to crack? Hemingray Tubes / Valves 6 7th June 2008 08:06 PM
luxmAN M-117 power realys SHOT! HELP! analogue_lover Solid State 5 26th May 2006 12:25 PM
this is like crack tenderland Full Range 14 25th May 2005 09:22 PM
A first crack at dipoles Roscoe Primrose Multi-Way 12 6th March 2004 08:29 PM
Page generated in 0.07443 seconds (65.12% PHP - 34.88% MySQL) with 10 queries
