Old 16th January 2011, 02:33 PM   #1
jacq. is online now jacq.  Canada
Default Any clue why large toro physically buzz's intermittently?
I have a large 2KVa toroidal that every once in while starts to hum (buzz, vibrate physically) intermittently. Not loud but noticeable. Anyone has an idea what causes such a behavior and how to avoid it?
Jacq.
Old 16th January 2011, 03:09 PM   #2
In short:
This has two reasons.
One is that the core alters its shape with an alternating magnetic flow through it. I forget the name of this effect.
Second is that magnetic flow and mechanical force always goes together. See a solenoid.
The windings sometimes can vibrate a bit.
Another reason could be DC on the mains. This can make the core to saturate which is bad.
The best measure against the first two causes is to drown the toroid in a vacuum environment with epoxy.
Against the DC you can use a filter but this is not convenient for a 2kVA toroid.
A workaround could be to mount the toroid using rubber mats to acoustically isolate it a bit and dampen the noise.
HTH
Old 16th January 2011, 03:14 PM   #3
llwhtt is offline llwhtt  United States
I have a 10 Amp Variac (essentially a toroid) on my bench and anytime something else on the same circuit is turned on it buzzes. It can be a mixer in the kitchen or the heat gun on my bench, always seems to be a motor that does it.
Craig
Old 16th January 2011, 03:30 PM   #4
jaycee is offline jaycee  United Kingdom
the mixer and heat gun probably use half wave rectification to alter speed. this will put DC on the mains and cause the buzz.
if you have this problem you can build a circuit called a DC trap to cure the problem. Basically this is two electrolytic capacitors say 4700uF 400V back to back bypassed by diodes.
Old 16th January 2011, 04:16 PM   #5
DF96 is offline DF96  England
Magnetostriction.
Old 16th January 2011, 04:17 PM   #6
Very illuminating. Thank you all for your inputs.
Jacq.
Old 16th January 2011, 06:20 PM   #7
smartx21's Avatar
Send a message via MSN to smartx21 Send a message via Skype™ to smartx21
Default DC FILTER
Although previously warned not to be used along with that power, attached are same variations for a mains DC filter.
We should not dwell on what we do not have, but, instead, be grateful for what we do have!
Old 16th January 2011, 06:27 PM   #8
smartx21's Avatar
Default Rubber mats
DIY rubber mats = rubber rings used to hold a car's exhaust + case foot!
Old 17th January 2011, 04:08 AM   #9
djk is offline djk
djk's Avatar
Note the Crown schematic detail. The big Crown (1160Wx2) uses two bridges in parallel with a soft-start, the smaller Crown (550Wx2) just uses one bridge.
Feel free to add the caps shown in the Bryston schematic detail, Crown doesn't think they are needed.
Candidates for the Darwin Award should not read this author.
Old 17th January 2011, 07:06 AM   #10
h_a is offline h_a  Europe
h_a's Avatar
The Crown version is simply a little less effective as it always cuts off 0.7V around 0 V.
With caps as in the Bryston version, AC always passes (with proper cap size) and only DC is cut off (up to 0.7V).
Just remember using high current bridges, standard heavy duty parts for PSUs are fine.
Hannes
PS: by the way, humm depends also on toroid design itself.
physically small twin triode tube sphinx Tubes / Valves 18 21st November 2009 05:43 PM
BLH for physically deep speaker? freddi Full Range 0 17th April 2007 09:08 PM
Bryston needs a clue classd4sure Class D 12 3rd August 2006 06:11 PM
Physically small rectifier tube with 5V heaters dsavitsk Tubes / Valves 7 14th June 2006 02:47 AM
Anyone know how to control a driver's room response physically??? (rather than L/C) Greggo Multi-Way 1 6th April 2004 04:09 PM
Page generated in 0.10418 seconds (78.32% PHP - 21.68% MySQL) with 11 queries
