simple MOSFET source folower suggest me please simple MOSFET source folower suggest me please - diyAudio
Old 24th July 2003, 06:31 AM   #1
aiwonsi is offline aiwonsi  Thailand
Default simple MOSFET source folower suggest me please
I found this schem in internet
http://home.zonnet.nl/tschrama/owndesign.html
can anybody suggest ?
how can I build power supply?
or more
I'm a newbie
some parameter
generator: 1K Ohm amperes: 2.618 Amp
device: IRF530S power@1%2/3rd: 7.558 Watt
z-Bias: 100K Ohm dissipation: 86.39 Watt
Bias Voltage: 25.2 Volt rendement: 8.749 %
z-source: 8 Ohm gain: 0.908 x
output capacitor: 4700uF Z-out: 0.2588 Ohm
supply: 33 Volt -dB @ 10 Hz: -0.6614 dB
z-speaker: 8 Ohm -dB @ 100 kHz: -0.0323 dB
rimple rejection: 0.648 %
THD@0.33Watt THD@1Watt THD@3Watt
0.125 % 2nd 0.223 % 2nd 0.432 % 2nd
0.006 % 3rd 0.022 % 3rd 0.079 % 3rd
Old 24th July 2003, 05:48 PM   #2
PMA is offline PMA  Europe
PMA's Avatar
Don't you want to try this one, you'll get better linearity and other parameters.
http://www.pha.inecnet.cz/macura/follower_e.html
Old 25th July 2003, 07:43 AM   #3
thank you
but can I use low voltage for low power?
thank again
aiwonsi
Old 25th July 2003, 08:10 AM   #4
Fuling is offline Fuling  Sweden
Go find (or wind) yourself a pair of big chokes.
YouŽll double the efficiency compared to a CCS design.
Something like 100mH is enough for 8 ohms load.
There are some threads in this forum about choke loaded solid state amps, have a look.
Old 25th July 2003, 08:30 AM   #5
Nicwix is offline Nicwix  Australia
I prefer this one ... the PSU is less critical. Obviously the PSU voltage and the CCS current can be scaled.
Nicwix
Old 25th July 2003, 08:52 AM   #6
PMA's Avatar
Hi aiwonsi,
yes, you can use lower voltage for lower power. In that case you have to maintain at Gate of T1 voltage Vs/2 + 4V. That means that for supply voltage of 24V you need 16V at gate of T1. This can be done by changing of R3 value. The circuit as shown (mosfet power follower) is not much sensitive to supply voltage ripple. The supply ripple rejection is about 60 dB, standard bridge and cap supply can be used. You will find one on my web page, same address as shown above. Fig.5. In case of more questions you can send me an e-mail.
Pavel
Old 25th July 2003, 10:59 AM   #7
thank everybody,
I'm a newbie.
I'm very fool about electronic.
I have some question.
I wan't about 5watt load 8 ohms. How do I change this circuit(power follower)? And why?
aiwonsi
Old 25th July 2003, 11:15 AM   #8
PMA's Avatar
For 5W/8 Ohm you need output voltage of 6.5Vrms.
P = 6.5 x 6.5/8 = 5.28 W
For 6.5Vrms you need supply voltage at least 20V.
Vs = 2 x 1.414 x 6.5 = 18.38 + saturation voltage of transistors.
For single ended class A you will need Iq (quiescent current) at least 1.2 A for 5W/8 Ohm.
Old 25th July 2003, 12:34 PM   #9
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Default mj amp
has anyone built the mj amp at the bottom of this page?
Curious about it.
Old 25th July 2003, 12:46 PM   #10
millwood is offline millwood  United States
Account Disabled
Default Re: mj amp
Curious about it.
this is one of those Mosquito/Zenquito designs that originally used JFETs upfront and Mosfets in the ops. In my simulation, it worked well, except that it has large cross-over distortion that i couldn't get rid of.
It originally attracted for its simplicity. and I would like to see other's experience with it as well.
simple MOSFET source folower suggest me pleaseHide this!Advertise here!
Layout and Pcboard software... please friends, suggest me something really simple destroyer X Solid State 102 21st July 2008 01:30 PM
Simple MOSFET amp bokakob Solid State 46 9th August 2007 12:42 PM
Dual Stereo Cathode Folower Setup satox Tubes / Valves 17 2nd September 2004 08:09 AM
Please suggest a source for 2sc2922: MCM is out again! grataku Solid State 1 26th April 2001 03:10 PM
Copyright ©1999-2017 diyAudio
