![]() I found a very simple circuit, but also very effective, sadly, no one seems interested in this circuit!
#2 |
Have you ever contemplated to use something better then the TL072 ?
Does it play, or is it just a schematic ? How about bias stabilty ? To make it work i miss the input resistors. Does it really work without compensation ? |
#3 |
In practice, to increase the number of protection circuits, but I think it is in line with the principle of simple and practical as possible to minimize the nonlinear elements, not only see the simple circuit, it went negative!
#4 | |
Its Class-a or ab........
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#5 |
#6 |
Yeah............
#7 |
This circuit belongs to class b, the input signal is divided into both positive and negative part of the op amp is a power tube amplification were the final synthesis, the amount of output signal proportional to the input signal is maintained by the op amp's feedback.
#8 |
U1B has positive feedback. Even if that's corrected the two opamps fight with their offset voltages--simply doesn't work in real world.
Samuel |
#9 |
![]() This is what I have been the actual assembly of the circuit, it works well, simple, sound is also very good. |
#10 |
That's a completely different circuit. Some might still argue that it's not the best power amp designed ever but it surely is simple and will pass audio.
Samuel |
| Anyone have a simple circuit for . . | gehumph | Tubes / Valves | 1 | 25th October 2009 05:52 PM |
| Looking for a simple circuit | Skitch72 | Tubes / Valves | 19 | 12th August 2009 07:31 PM |
| Help me with simple circuit | valterdaw | Car Audio | 2 | 22nd August 2006 07:15 AM |
| Problem with really simple circuit! | Garbz | Solid State | 14 | 8th March 2006 03:18 PM |
| simple circuit for beginner | JAZZ2250 | Tubes / Valves | 4 | 8th April 2002 01:33 AM |
| Page generated in 0.11969 seconds (72.93% PHP - 27.07% MySQL) with 11 queries |
