Sony TA-F6B PSU repair
Old 15th September 2013, 03:10 PM   #611
Mooly's Avatar
Not an R or should that be Another from a different batch has L5YS as the code. These were Sony supplied devices for the SLC7UB betamax VCR if I recall correctly.
I've no idea what the letters stand for and what the differences in selection might be.
Old 15th September 2013, 03:16 PM   #612
jan h is offline jan h  Denmark
Could it be the housing, like the BUT11AF is isolated?
Anyway only the TU version is in stock, so I guess it'll have to do.
Old 15th September 2013, 03:24 PM   #613
Mooly's Avatar
Dunno. These are standard packages with all metal tabs.
Old 15th September 2013, 04:32 PM   #614
jaycee is offline jaycee  United Kingdom
TU just means supplied in tubes, as opposed to loose, or on tape.
Old 15th September 2013, 05:01 PM   #615
Ah OK, so the transistors are the same, thanks, jaycee
Old 15th September 2013, 07:52 PM   #616
amc184 is offline amc184  New Zealand
amc184's Avatar
I bought the KSC2335s from Futurlec, where they were listed as 2SC2335s. The 2SC2335-K is equivalent to a KSC2335-Y, the NEC ones were binned M, L, K, while the Fairchild replacements are binned R, O and Y, but the ranges of each bin are the same.
It looks like the digikey listing was for KSC2335-Rs in particular, which is good, those are the best match I think. I'll see if I can match any that I have left.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 15th September 2013, 11:00 PM   #617
Old 6th October 2013, 11:17 AM   #618
Have you powered it up yet, amc184?
Old 7th October 2013, 09:36 AM   #619
amc184's Avatar
No. The last of the parts for it arrived, and I've installed them, but I've not found the time to actually power it up yet. There'll be a few parts to it as well, I'll have to test out the HV rectifier and softstart on the mainboard first.
Old 3rd January 2014, 02:53 PM   #620
Time for a update
I'm pretty sure the 2023's from Dönberg are fakes, the PSU made the familiar high pitch sound, only about 60V output, and after less then a minutte they shorted...
The good news is the KSC2335RTU from mouser works perfectly, no high pitch sound, could easy adjust output to 99V, the speaker relay click in, and the amp plays
Another sign that the 2023's are fake is the hFe, on 15 transistors whit same markings it ranges from 9.5 to 38.
Where as the KFC2335RTU's all 15 transistors measure between 20 and 21.
As for the meter light not working, the bulbs are not original, so the big question is what V and mA should they be?
I'm pretty sure they should be around 6.3V, but some say 250mA others say 70mA.
Sony TA-F6B PSU repairHide this!Advertise here!
schematics sony Ta- F6B max29 Solid State 5 17th March 2011 08:36 PM
SONY TA 70, repair help needed jojospecial Solid State 2 5th November 2008 09:15 PM
Sony TA-AV670 amp repair calum112 Solid State 2 27th March 2007 09:38 PM
Sony TA-N1 and TA-NR1, how do they sound? lumanauw Solid State 0 28th November 2006 02:51 AM
FS: Sony "Esprit" TA-E901 and TA-N901 pre and power amp MJR Swap Meet 1 6th December 2003 08:55 PM
