Sony TA-F6B PSU repair
Old 22nd January 2013, 07:37 PM   #541
Mooly's Avatar
It was a bit of a marathon thread for sure
Old 29th January 2013, 06:47 AM   #542
BANG PHI is offline BANG PHI  Viet Nam
My sony TA F6B amplifier is damaged. Transistor Q352 and resistor R362 are high temperature. Is The IC CX 171 broken, please advise me
My english is bad
Old 29th January 2013, 08:22 AM   #543
Mooly's Avatar
You would need to do a lot more tests. The IC might be unobtainable now which could be a problem.
Check the supplies to the IC
Check the two 0.22 ohm resistors on the output stage. If open circuit then you have an output problem.
Check the voltage across those two zeners near the IC.
Old 29th January 2013, 10:48 AM   #544
I replaced two zeners 22V, but the transistor Q352 and the resistor R 362 are alway very hot, The output stage is 49V, but two transistor output stage are good. Why?
I shall check the supplies to the IC, please show me how to check the IC
Old 29th January 2013, 12:05 PM   #545
Mooly's Avatar
Check the 8 and -8 volt rails on pins 4 and 14 of the IC.
Check that there is no DC voltage (<0.1DC) across the base and emitter junctions of Q355 and Q356.
Old 29th January 2013, 02:02 PM   #546
I am going to check Q355 , Q356, and report to you.
Old 31st January 2013, 07:11 AM   #547
I replaced Q 355 ana Q 356 but the transsistorQ352 and resistor 362 are still very hot
Old 31st January 2013, 07:32 AM   #548
Mooly's Avatar
Did you check the voltage across the base and emitter junctions with the amp on as mentioned earlier ?
I didn't suspect those transistors as being faulty. The test was to see if they were turned on
tbh I think you are going stuggle with with this. Its a complex amp and the IC is an unknown as to whether its good or not. You could always swap the IC with the other channel and see if the fault transfers over.
Old 1st February 2013, 09:31 AM   #549
Why check the voltage across the base and emitter junctions Q352, Q353?
If there is DC voltages? Is the IC damaged?
Old 1st February 2013, 02:31 PM   #550
Mooly's Avatar
It would show if they were turned on and conducting. You have to measure across the junctions to get an accurate reading.
I don't know if the IC is damaged or not at this stage.
Sony TA-F6B PSU repairHide this!Advertise here!
schematics sony Ta- F6B max29 Solid State 5 17th March 2011 08:36 PM
SONY TA 70, repair help needed jojospecial Solid State 2 5th November 2008 09:15 PM
Sony TA-AV670 amp repair calum112 Solid State 2 27th March 2007 09:38 PM
Sony TA-N1 and TA-NR1, how do they sound? lumanauw Solid State 0 28th November 2006 02:51 AM
FS: Sony &quot;Esprit&quot; TA-E901 and TA-N901 pre and power amp MJR Swap Meet 1 6th December 2003 08:55 PM
