Hi guys,
you are much more into this than me ,so I have a question regarding transistors matching:
Is there any site with online transistor search by parameters so you can use that to find a match for symetrical amplifier output transistors..
Case-study;
I have 2x 2n4347 output transistor, and 2x ??? (erased label) transistor that are paired 2x(2x) to be in push-pull configuration.
While its really easy to find datasheet for this transistor,I could not find a easy way to search complementary transistor match 120V/100W/TO-3 to see what is connected at the PNP "side".
Case-study;
