Old 13th January 2011, 05:06 PM   #1
BigE is offline BigE  Canada
Default Input impedance of Phase linear 400
I have the PL14 boards, with 39K input impedance. I want to go to 60K or more.
Is it sufficient to change the resistor across the input to the amp to change input impedance?
thanks!
Old 13th January 2011, 11:34 PM   #2
djoffe is offline djoffe  United States
Default Different Vintages?
I found a schematic online of PL400. From the look of this one, Zin would be about 12700 Ohms. Does yours have much higher input resistors? If so, was it a mod, or just a different vintage?
OK...here's a hint, the website:
Phase Linear PL-400 | Owners Manual, Service Manual, Schematics, Free Download | HiFi Engine
said:
Input impedance: PL400C-47 kOhms, PL14A-10 kOhms, PL14B-39 kOhms
I'm thinking that I may not have all the details, since there's no input blocking cap, but maybe this was just an amp for the brave.
Anyway, if you change R3, the only issue will be a bit of offset voltage at the output. If this schematic is correct, the diff pair transistors each have input bias current of around 75/200000/2/150=1.25 micro-Amps. If the input were AC coupled, then the output offset due to input bias current would be about (R3-22000)*1.25e-6.
If you choose R3=100K, the speaker offset voltage would change from its present value (assumed due largely to offset voltage) by 97.5 mV. That's probably tolerable.
File Type: pdf phase-linear-400-power-amplifier-schematic.pdf (58.0 KB, 58 views)
Old 14th January 2011, 01:29 AM   #3
djk is offline djk
djk's Avatar
Bootstrap the input impedance.
http://passdiy.com/pdf/a40.pdf
Candidates for the Darwin Award should not read this author.
Old 14th January 2011, 02:10 PM   #4
Mine is the 39K version.
how can I post the schematic? I have no web-site for it....
In my amp, R1 = 1k, R2 = 39K and C22 = 220pF
Old 14th January 2011, 02:18 PM   #5
I don't have the level of sophistication to modify the driver board and circuit.
Also, the text shows a bootstrap circuit of 40K, while the PL has 39K.
Old 15th January 2011, 08:28 AM   #6
djk is offline djk
djk's Avatar
http://www.dvq.com/hifi/images/phase400.pdf
Change R2 to whatever you want, adjust R8 for minimum DC off-set.
Old 15th January 2011, 12:10 PM   #7
Default How many versions?
Does anyone have an idea of how many rather different schematics were used for the Phase Linear 400? The one that djk just posted (thanks!) is very different than the one I found and posted...How many other variations are out there?
Old 17th January 2011, 02:42 PM   #8
My input board is the PL-14, not the one in that schematic.
The PL 14 is far different than that... it uses a second differential pair; there is no 100K pot like R8 on the board.
I'm thinking that the input resistor (R1 = 10K) that is in the signal path to the first differential pair Q1 and Q2, and the resistor that sets input impedance (R3 = 39K) form a voltage divider.
So if I want to increase the impedance of R3 by 1/2, then I should increase R1 by 1/2 as well. So with R3 at 60K means, R1 should be about 15K.
I'm assuming that 1/4 watt resistors ought to be good enough.
Old 17th January 2011, 02:43 PM   #9
There are three in the Service Manual found at www.hifiengine.com
Old 17th January 2011, 06:16 PM   #10
thanks for the hifiengine link...I checked the schematics there in the service manual that seems like yours...my earlier calculations should be ok...it's close enough...if you make R1 go from 10K to 15K and R3 go from 39K to 60K, everything should still work fine. As you suspected, 1/4 Watt resistors are plenty big enough.
Good luck...and be careful...
Phase Linear 400 BigE Solid State 20 7th January 2011 02:44 PM
Need help fixing an odd Phase Linear 400 blue lander Solid State 91 20th August 2009 02:46 PM
Phase Linear 400 Question mrfeedback Solid State 49 9th May 2009 03:59 PM
Phase Linear 400, SERIOUS AC! Planerguy Solid State 41 29th March 2009 02:41 AM
Phase linear 400 driver replacement The Donk! Solid State 13 22nd March 2008 04:38 PM
Page generated in 0.15174 seconds (70.26% PHP - 29.74% MySQL) with 11 queries
