One (1!!) transistor clapping... - Page 24 - diyAudio
Old 12th October 2004, 05:40 PM   #231
PMA is offline PMA  Europe
PMA's Avatar
Be careful, you are going to dissipate 94W on every of the MOSFETs ....
You might like to start with 8R resistors.
Old 12th October 2004, 08:10 PM   #232
Default fan cooling?
If i use a small fan for cooling... can I get away with 1 mosfet per channel??
Thanks!!
It is not you... you are it.
Old 12th October 2004, 08:19 PM   #233
PMA's Avatar
You will have to know thermal resistance of the transistor (depends on package and chip), insulating pad and heatsink. Take into account that 1C/W of the summarized thermal resistance will cause 100C increase of chip temperature (provided there is a 100W power dissipation).
Old 23rd October 2005, 05:16 PM   #234
Bernhard's Avatar
Originally posted by janneman
The 2SK60 and it's complementary device 2SJ18 are both enhancement types which were used by Sony in for instance their TA-N7 in the late 70's.
They were used as cascodes for the output stage, which had low-voltage bipolars driving the load.
Jan Didden
Why not the other way round ? Bipolar as cascode for the V-fet ?
Old 23rd October 2005, 08:28 PM   #235
ilimzn is offline ilimzn  Croatia
First, because the bipolar has a higher Gm, which makes some things easyer, and second, because the VFET, unlike the bipolar, does not have a secondary breakdown problem - so you want to keep the voltage across the bipolar relatively low.
Old 23rd October 2005, 09:38 PM   #236
Bernhard's Avatar
OK,
but wasn't the Vfet originally used (in the earlier amps ) for high speed, good linearity and because it is a voltage controlled device ?
But in the TA-N7 ( which I own ) the gain device is bibolar, is this still a Vfet amp ?
Any sense to built a single ended classA amp with N-Vfet and bipolar or mosfet current source ?
Old 30th June 2009, 02:36 PM   #237
Hello,
today the 2SK70 and 2SJ20 V-Fet In this form, what alternatives might be?
hard to find.
best regards. Can.
Old 4th December 2009, 04:33 PM   #238
CFT is online now CFT  United States
Can someone share a circuit design using single ended 2SK60 or 2SJ18?
Would be nice to mate it with a DHT preamp
(something like the circuit shown in the #23 thread)
Gainclone-the sound of one channel clapping/Happy as a pig in mud Dr.H Chip Amps 10 13th August 2003 01:04 AM
Copyright 1999-2017 diyAudio
