hi guys
i am new to the world of audio electronics and was wondering if you could shed some light on the following schematic i have been given as part of an assignment. i am roughly confident with the phantom power part ( capacitors used to block dc signals and act as a filter to remove noise right? aswell as the resitors attenuating power/noise right? pretty confused with the pad part as to why the 220resistor has the option to be connected or not, the rest im pretty uncertain on. if any one could take me throught the flow of the circuit and why such components r used i would be eternaly grateful. part of the brief below if any1 feels like doing any of the math and explainig how i would again be very grateful but the signal flow would very very grateful thanks a lot stevie should produce a report describing, analysing and calculating the provided circuit to prove theory of operation and design choice. The preamp should be compared to existing designs and should be described at component level with supporting math and technical referencing. You can also provide real world measurements and sound clips to aid your discussion of the provided circuit. Areas to discuss include: Phantom Power Transformer Ratio Impedance Reflection Loading - Fixed, Reflected, Variable and Capacitive Common Mode Rejection Balanced to Unbalanced Connection Mic to Pre Source/Load Relationship Gain Stages – Feedback Control Frequency Shaping of Gain Gain (Av) and dB Gain Bandwidth Frequency Response Distortion – Clipping, Headroom (Maximum Operating Levels) and Magnetic Saturation AC Coupling / DC Blocking
#2 |
any help?
#3 |
If we do this for you do we get the marks instead of you?
#4 |
haha sorry i no seems like a bit much. i wasn't expecting any1 to really go in 2 deep. but if any1 could help with with a brief explanation of the components used it would be great, just quite confused about the gain stages and the numerous resistors and capacitors
#5 |
Rs in series with pots limit adjustment range - perhaps to avoid problems.
There are some RC combinations that serve to limit bandwidth, as well as reduce gain at high frequencies. There are caps to ground that reduces gain to 1 at DC. A pot+R and other Rs to set the load seen by the input Caps to block DC seen by the output. Bonus points if you figure out why two of such different values. There are Rs to limit current and some to set gain. There are Cs to filter noise Now you need to figure out which are which. Last edited by BobEllis; 11th January 2011 at 06:23 PM. |
#6 |
#7 | |
![]() N1 (ALOL) Recks U C THIS ISNT TWTR U NO (BYKTC)
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#8 |
sorry i thought it was slightly more acceptable on the internet..didn't mean to get any panties in a twist
. thanks for your reply bob the circuit is begining to make a lot more sense. i wasn't aware that it mattered that too much if the capacitors were of different values...only that one removed high frequencys like mains hum and the other outside interference like radio ...im probably wrong about that to. il refrain from posting anymore, i was only asking for a push in the right direction |
#9 | |
But remember you learn by experience and by doing and measuring... and making mistakes... there are no shortcuts... it all becomes a lifetimes knowledge.
#10 |
You'll often see a moderate value film cap in parallel with an electrolytic. The purpose is pretty much as you surmised. Electrolytics are relatively cheap and small, allowing a great deal of capacitance in a small package. The downside is that they often have poor high frequency performance. Place a film cap parallel and you only need a small capacitance to handle the high frequencies. You could do it all with a film cap, but it would be expensive and huge. BTW, mains hum is low frequency.
| MC pre pre amp for shelter 501 MK11 | cjcc67 | Analogue Source | 19 | 24th May 2010 07:17 PM |
| Blown amp pre-amp in or HU pre-amp out? | scraph | Car Audio | 5 | 23rd January 2009 12:58 AM |
| 6V6GT scematic, any good, comments? | ak_47_boy | Tubes / Valves | 8 | 22nd December 2006 05:58 PM |
| Nak OMS-7 II Scematic or manual ? | anatech | Digital Source | 0 | 22nd December 2005 11:16 PM |
| Page generated in 0.23755 seconds (42.82% PHP - 57.18% MySQL) with 10 queries |
