Old 10th January 2011, 09:51 PM   #1
kees52 is offline kees52  Netherlands
Default HYBRIDE AMPS
Hi there
I have here a schematic of a hybride with a tube 6C14N high transductance tube with a local current feedback bipolair amp, you can freely use it and simulate for your own, it is maybe interesting to make as the first hybride with bipolairs here.
Maybe a apart section for hybrides can be nice..
schematic can be load in multim 11.
Old 10th January 2011, 10:21 PM   #2
Another file.
these design have a offset tracking opamp so it is not sensitive to drift caused by tube and current feedback, it gives a blockwave of 20 khz without delay or overshoot, (only simulated without load).
I now it is sometimes strange stuff but we have to keep trying to combine already known stuff in the amp world.
Old 21st August 2011, 07:02 PM   #3
This one I have in my home, it is these week changed in what it is now, the sound is open, fast, steep and with a big soundstage and resolution, the used tube in the first stage is a JJ high and low mu valve, ecc832, http://www.jj-electronic.com/pdf/ECC%20832.pdf
In the schematic it is 12ax7 and 12au7 I have not a model for ecc832.
Also a single ecc803 with gyrator is fine sounding, but ears are also very differend.
I can say this design has a very close tube like sound, and is faster and more control over speakers, that was my goal.
But maybe it can stil better, so light your brain.
Old 21st August 2011, 07:05 PM   #4
The penthode however is a EL84, I was forgotten I have also not a model for it and use the 6l6qc
Old 21st August 2011, 07:13 PM   #5
farjon is offline farjon  Brazil
farjon's Avatar
Originally Posted by kees52 View Post
Hi there
It is possible multim 10 versions?
Old 21st August 2011, 07:35 PM   #6
Here is a model for the 6BQ5, said to be equivalent to the EL84.
* Filename: 6bq5.inc 23/01/2004 V4
* Simulator: PSpice
* Device type: Power pentode
* Device model: 6BQ5/EL84
* Author: Duncan Munro
* Date: 12/5/97
* Copyright: (C)1997-2004 Duncan Amplification
* V3 [12/10/97]: Screen current limited to prevent screen current
* draw at Vs = 0.
* V4 [23/01/04]: LIMIT{x,y,z} statements changed to LIMIT(x,y,z)
* The following parameters are not modelled:
* (1) Heater
* (2) Grid current is an approximation
* Please note that this model is provided "as is" and
* no warranty is provided in respect of its suitability
* for any application.
* This model is provided for educational and non-profit use.
* Queries via the forum at Duncan's Amp Pages
* Pins A Anode
* S Screen
* G Grid
* K Cathode
.SUBCKT 6BQ5 A S G K
* Calculate contribution to cathode current
Eat at 0 VALUE={0.636*ATAN(V(A,K)/15)}
Egs gs 0 VALUE={LIMIT(V(S,K)/19+V(G,K)+V(A,K)/1400,0,1E6)}
Egs2 gs2 0 VALUE={PWRS(V(gs),1.5)}
Ecath cc 0 VALUE={V(gs2)*V(at)}
* Calculate anode current
Ga A K VALUE={3.2E-3*V(cc)}
* Calculate screen current
Escrn sc 0 VALUE={V(gs2)*(1.1-V(at))}
Gs S K VALUE={2.0E-3*V(sc)*LIMIT(V(S,K),0,10)/10}
* Grid current (approximation - does not model low va/vs)
Gg G K VALUE={PWR(LIMIT(V(G,K)+1,0,1E6),1.5)*50E-6}
* Capacitances
Cg1 G K 10.8p
Cak A K 6.5p
Cg1a G A 0.5p
.ENDS
Old 21st August 2011, 07:37 PM   #7
Most of the time newer files can not load into older programs.
You can try otherwise drawn it over, al the parts are in multisim 10,
Old 21st August 2011, 08:08 PM   #8
These are the blockwaves with this amp, 20Khz.
I have tryed the model posted, but I am not so clever in make a model working with a part in multisim, with I copy from a excisting penthode part, I will go some days praktice with it,.
Old 22nd August 2011, 10:28 AM   #9
Well I have studie multisim, now I now how to make models.
I have simulate now EL34 as a mosfet driver and distortion is even lower setting the EL34 on a idle of 40 mA, now I can drive the most big mosfets without loose bandwith.
Multisim is also very buggy, sometimes it will not simulate, or I get database errors, copy the schematic in a new project it work again, versie 11 is more worse then 10
but if it work it is one of the finest and easyest software..
Old 23rd August 2011, 03:52 PM   #10
I have perform a spectrum analyzer test, not much harmonics, only a small second one, that is good..
So it is fearly low THD.
DIY Planar magnetic Hybride WrineX Planars & Exotics 61 13th January 2012 07:55 AM
Hybride bipolair amp kees52 Tubes / Valves 29 23rd August 2011 06:43 AM
bridged UcD-like hybride Kuzmenko Class D 3 5th July 2009 08:27 PM
mugen hybride jopie Tubes / Valves 2 2nd April 2008 04:09 PM
DIY Hybride amplifiers Gydotron Tubes / Valves 21 22nd February 2005 03:37 PM
Page generated in 0.19346 seconds (57.74% PHP - 42.26% MySQL) with 11 queries
