Old 10th January 2011, 05:12 PM   #1
ID_ is offline ID_  Slovenia
Default NMOS 350/500 by Quasi
Hello to all.
I decided to build the mentioned amp, becouse the one other that I got blew.
The schematic can be seen here
So I fallowed the construction guide and assembled the amp. Everything seemed to be ok. As I vas setting the bias I noticed, that the current was increasing with the temperature increase of T6,7,9 and 10 (they are mounted on common heat sink). I'm worried about this becouse of thermal runaway. When the temperature of this common heat sink settled the bias was steady, but heat sink was extremely hot to the touch. I've let the amp run about 1 hour. Everything seemed to be ok, except the small common heat sink teperature. So I decided to test the amp with some loudspeaker. I connected everything and there was some noise comming out of speaker (not humm). So I disconnected the input (I tought maybe it's the faulty cable) and then it happened. As soon as I disconnected the input I noticed smoke and the noise went crazy (I almost crapped myself ). So I instantly turned the amp off.
The resistor R20 lost his smoke. I measured every transistor and fet! They are all ok. Just the R20 blew!
I checked and rechecked every connection and whole PCB assembly before I wired the thing together. All was OK!
I was running the amp on +- 81V!
I can't find the error, so maybe someone can help me!?
I have no idea what have gone wrong!
Old 10th January 2011, 05:55 PM   #2
I have a very similar circuit running on 50V rails and its stable. However VAS and its current source are not mounted to a heatsink and the drivers doesent have a heatsink.
The drivers get hot but not burning hot.
Its possible that 81V rails are just too much since it was designed for 75V rails.
Old 10th January 2011, 06:10 PM   #3
jackand08's Avatar
You say that T6,7,9 and 10 were on a common heatsink but for the temperature compensation of the bias to work properly, it is also important that T8 is mounted on the MAIN heatsink with the output transistors. This is just a suggestion as you doesn´t say anything about T8 in your first post.
Also, are you sure that your amp really does have an adequate heatsink for use with higher voltage rails. Rails of a higher voltage will increase dissipation in the output transistors and may result in the idling temperature being quite a bit higher than expected.
As Tekko says, it may well just be that +/-81V is pushing it too much for an amp designed to work on +/-75V. Remember with +/-81V rails, it is a total difference rail to rail of around 162V which certainly isn´t a low voltage.
Jack
"Near enough is good enough, so good enough is right" My Site
Old 10th January 2011, 06:35 PM   #4
I'm aware of this voltage difference! Quasi said in some other thread that the amp was designed to run at maximum +- 85V.
Yes, I forgot to mention, that T8 is on the main heat sink!
Old 10th January 2011, 06:39 PM   #5
moschfet's Avatar
Hi ID,
Noise are signs of oszillations. The louder the more.
Good old problem
Have you got an oscilloscope?
Old 10th January 2011, 06:52 PM   #6
I have osciloscope- maybe some advice on how to make a measurement.
The FETs do not come cheap and I do not want to smoke them!
Oh and just to mention, I took Quasi's PCB design, so in general it should work!
Old 10th January 2011, 07:08 PM   #7
moschfet's Avatar
using an oscilloscope
Why, are there many who build an amplifier with this layout?
Old 10th January 2011, 07:29 PM   #8
Few people including this forum have mentioned that they've build the amp yes.
Old 10th January 2011, 07:47 PM   #9
moschfet's Avatar
Can you show me the layout?
Old 10th January 2011, 08:16 PM   #10
Here are the PCBs and layouts.
Help needed! strange sound from nmos quasi amp sanju21 Solid State 10 24th April 2012 09:03 AM
Wildcard Power Amp dev. thread (SMD, Quasi NMOS, IRFP260, digital bias) danfo098 Solid State 2 16th May 2011 08:57 PM
Which is Beter Quasi Or Non Quasi sekhar Solid State 87 22nd June 2010 08:12 PM
Need assistance for additional devices in DC detect for Quasis NMOS 350 Amp qsa Solid State 1 22nd November 2008 10:43 PM
Page generated in 0.17962 seconds (52.31% PHP - 47.69% MySQL) with 11 queries
