Need repair info on SWTPC 215/A Power Amp
Old 9th January 2011, 09:04 PM   #1
vinylvirgin is offline vinylvirgin  United States
Default Need repair info on SWTPC 215/A Power Amp
I need a service or kit-building manual for a SWTPC 215/A stereo power Amp. Also, can the two now-obsolete and unobtainable FP-type can power supply capacitors (each 4000 uf at 50V) be replaced with modern axial- or radial-lead caps of the same value? I've been told that as long as the new caps have the same electrical values as the old ones there should be no problem. Is that really so?
Also, I need service info for a Technics SA-5250 stereo receiver.
Old 10th January 2011, 03:54 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Hi, Don't know about the service manual as it depends on the popularity
of the brand.Yes you can substitue modern caps but I think the closest
value would be 4700uF 50V.You can go up to 10000uF if space permit.
Regards.
Old 10th January 2011, 09:21 AM   #3
djk is offline djk
djk's Avatar
Try contacting these guys:
Geting back into Vintage Stereo - AudioKarma.org Home Audio Stereo Discussion Forums
Candidates for the Darwin Award should not read this author.
Old 10th January 2011, 10:11 AM   #4
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
I think the 215A is the Dan Meyer Tiger amp? there are a number of design problems with these amps and many great articles on rebuilding them here and in Audio Amateur if i am correct. I would not attempt repairs on one until the AA article has been read or you have research previous posts here on the subject.
Zc
It's not about what you can BUY...It's about what you can BUILD!
Old 10th January 2011, 10:37 AM   #5
djk is offline djk
djk's Avatar
The 215/A is a 25W per channel stereo version of the Tiger 0.01
Old 10th January 2011, 01:04 PM   #6
PB2 is offline PB2  United States
PB2's Avatar
I think it is a scaled down version of the .01 as djk mentions, here is the .01 documentation: SWTPC Tiger .01 207B Schematic
Need repair info on SWTPC 215/A Power AmpHide this!Advertise here!
Sugden a21a power amp repair adamus Solid State 12 11th January 2014 05:29 AM
Robert Grodinsky Research Pre & Power Amp info? thejohn Solid State 13 8th October 2011 12:22 PM
CM915 Power Amp Info jud1 Solid State 0 17th June 2010 03:26 PM
Precision Power amp needs repair....but where? PPIintegra Car Audio 10 31st May 2010 05:12 AM
power amp repair cracklin audio Solid State 23 27th March 2008 03:05 PM
Copyright ©1999-2017 diyAudio
