Old 9th January 2011, 09:14 AM   #1
Hodgie is offline Hodgie  Australia
Default Help for novice - faulty amp
Hi all,
I am a novice in terms of most things audio, but have been lucky enough to acquire some vintage components over the last few years.
One is a Phodis CE-6000 amp, which I believe to be a relatively short run Japanese item - more readily found in the southern hemisphere, especially Australia and New Zealand....(I'm starting to sound like David Attenborough!!)
The problem I have is with distortion / crackling at low volumes as I turn the volume knob.
Once I get past a certain point in volume (quite loud), the crackling disappears and the sound is beautifully clear in both channels.
The problem is most noticeable in one channel, but does affect both channels.
I have checked all the obvious things like loose wires etc, and cleaned the RCA jacks etc, but this is the limit of my DIY skills at the moment.
I understand that this may be difficult to answer for such a relatively unknown amp, but I suspect (hoping!!) that it may be a generic issue rather than one specific to this brand/model amp.
BTW - any one with knowledge of Phodis? Not much out there in the ether, so any clues would be good.
Hodgie
Old 9th January 2011, 09:29 AM   #2
Bone is offline Bone  United Kingdom
Sounds like the volume pot is worn. You can try squirting switch cleaner in it but the noise will come back again after a while. Best to change it for a new one.
Tony
Old 9th January 2011, 10:47 AM   #3
Thanks for such a quick response Tony.
As a rank amateur, one other question - what would a "volume pot" look like?
Is this a diode/resistor/capacitor or other such electrical component that I'm trying to identify, or something elese entirely?
Apologies, but I really am new to this stuff.
Hodgie
Old 9th January 2011, 12:42 PM   #4
jaycee is offline jaycee  United Kingdom
It's the control itself - pot is short for "potentiometer". It'll have 6 terminals which means it's really 2 potentiometers in one (one for each channel).
Old 25th January 2011, 06:53 AM   #5
Hi all,
sorry for the delay, but just wanted to update on the successful cleaning of the pots with switch cleaner - easiest 'repair' I have ever done!
Many thanks for the advice.
Hodgie
Complete tube amp novice got a few questions!! Boscoe Tubes / Valves 22 22nd August 2010 04:52 PM
MICROMEGA Drive 3 & DAC Faulty & MODS eldarvanyar Digital Source 7 28th April 2010 07:30 PM
Help needed - Novice PWM Amp - not working [-_-] Class D 44 12th March 2009 08:07 AM
denom pma250 amp faulty,but no faulty parts found please help homertooties Solid State 1 7th December 2008 03:58 PM
Faulty amp - diagnosis? Omega_Void Solid State 7 11th July 2008 10:52 AM
Page generated in 0.07786 seconds (74.97% PHP - 25.03% MySQL) with 10 queries
