Old 8th January 2011, 08:26 AM   #1
Default Is this a proper heatsink for AV800
I want to use this heatsink to built the AV800 and i want to know if it is big enough
Old 8th January 2011, 09:13 AM   #2
AndrewT is online now AndrewT  Scotland
what do the internal fins look like?
Is the fan working efficiently at pushing cold air through the sink tunnel?
regards Andrew T.
Old 8th January 2011, 09:55 AM   #3
The efficiency of the fan is 50%,and here is a picture of the fins
Old 8th January 2011, 10:36 AM   #4
I guess this is not a heatsink. It's more likely looks as a piece of granit rock to be used as heatsink!
Btw, good idea, considering high prices for precious metals, granit electrical non conductivity there is no need to use any kind of washer only thermal compound!
One thing left to calculate a formula of its thermal conductivity to obtain a C\W ratings.
If for pristine and pure adoration - it's diyAudio dedication!
Old 8th January 2011, 10:49 AM   #5
are the fan blades clean? Are the sink fins clean?
Are the inlet and outlet ports clean?
Is the oil in the fan bearing clean and to specification?
Are you still sure about your cooling efficiency?
regards Andrew T.
Old 8th January 2011, 10:57 AM   #6
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Find out what the thermal resistance of it is, both the Cordell and Slone book tell you how. Here's a quick answer:
Get known value power resistors, and clamp it well to the heatsink
Dissipate a known power in the resistor for a long period of time. For your heatsink, you'd want to use multiple resistors on both sides to distribute the power like you will when you bolt a lot of output transistors to it.
Measure the temperature rise of the heatsink over the course of a few hours. Calculate C/W rise using the measurements of rise and power.
Determine how much output power you think you'll dissipate in the AV800 stage.
Figure out if you can live with the temp rise you'll have.
www.stuffscottbuilt.com
Old 8th January 2011, 12:02 PM   #7
I do not think I know how to calculate C/W and the other stuff and I dont have how to calculate them picose i didn built the amp ,i will built it but first i need to make some money,I have the transformer suply capacitors pcb.
Old 8th January 2011, 12:39 PM   #8
For andrewT everyting is clean , i aproximated the eficency by comparing the power of the air flow when the fan is in the air and mounted
Old 8th January 2011, 03:19 PM   #9
I looked at specs from heat sinks that look similar and would guess this one could have something like 0.3 to 0.2 K/W which should be sufficient for an AV800 amplifier.
I'd give it a try.
Just my opinion.
AV800 Amp Jitterbug Solid State 9 16th July 2010 10:14 AM
AV800 again :D dziundzis3 Solid State 0 26th November 2009 02:15 PM
av800 pcb need help!!!! ashokavarthanan Solid State 12 10th October 2007 01:12 AM
AV800 + clipping , etc ... darkm4n Solid State 14 24th September 2006 01:51 PM
Page generated in 0.10685 seconds (79.69% PHP - 20.31% MySQL) with 11 queries
