#41 | |
I'll take a look tonite, I'll have to grab a variable attenuator on my way home. How do you measure 120VAC? I am afraid I'll fry something... |
#42 |
WHats that smell...
Urine! Ive jumped into yet another DIY ****ing match. I'm outa here before my otes get wet. Ciao! http://millinfo.org/upsfire/ |
#43 | |
I would stick around if I were you. Some good may still come from this thread. I don't like to propagate flames anymore, but I needed to say something. |
#44 | |
diyAudio Senior Member
All the UPSs I've seen from APC do that as well...there's probably little point in switch it on/off anyway. Cheers,
Frank |
#45 | |
Add a highly non-linear load (rectified DC supply) and all the low distortion performance in the oscillator goes out the window, as bad, if not worse, as the conventional mains. You can add feedback at LF around the transformer, but can't really extend this beyond very low frequency, due to the phase shifts. Did you measure THD at the o/p under a real world load? BTW, those that think the incoming mains is a nice 50Hz (or 60Hz) sine, think again Here's mine at various times of day, it peaks around 5-6% THD at busy times, drops to 1/2 to 1/3 this late at night, with mainly the high-order harmonics falling... |
#46 | |
#47 | |
The problem here is that the mains distortion comes primarily from the non-linear loads connected. Most LPF's I've tried raise mains Z to much, and this is actually more audible than the distortion already present and whilst isolating the equipment from the mains distortion, it then increases it within the device, due to the small conduction angle of rectified mains supplies. Some attention to power factor correction is the order of the day, I feel. Interestingly the power plant devices have the option of more distorted, non-sinusoidal ouptuts, which are reported to sound better - I wonder if it's some simple attempt at pre-distirtion, in an attempt to improve the result under load? Andy. |
#48 |
this is the filter used in one of the ARRL power supply designs:
#49 | |
Harmonics add nothing to efficiency, they actually add to the useless power that needs to be dissipated in the step up and down transformers and as such an attempt is made to minimize them as much as possible during generation. As stated before, a large portion of harmonics are generated by the load. In some parts of europe power users above a certain number of kW are required to rephase their inductive or capacitive loads so as to "look" resistive from the standpoint of the supply that helps ,I think. |
#50 | |
Not anymore nowadays for the average household but still the norm for industrial apps. Cheers,
Frank |
| cheap DIY PURE AC regenerator | audiojoy | Power Supplies | 46 | 9th October 2010 10:08 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 09:52 AM |
| Gainclone as AC regenerator | MtBiker | Chip Amps | 10 | 29th April 2005 05:55 AM |
| 1-tube Regenerator | planet10 | Everything Else | 2 | 17th March 2005 02:22 PM |
| Page generated in 0.14434 seconds (76.25% PHP - 23.75% MySQL) with 11 queries |
