#11 |
diyAudio Retiree
"It could be probably quite easy to modify it into true power regenerator"
Tell us how then........ The fews UPS I have played with sounded pretty bad. I think it might be a total waste of time to modify one. The money would really be better be spent on a decent power transformer and a DIY amp and oscillator. This is really a pretty simple project I have seen plently of one op amp oscillator circuits around that you can probably build with Radio Shack parts. Do not use a funstion generator IC they have an incredible amount of distortion. it is not that hard to build an analog circuit to very the shape of the waveform to lengthen the diode conduction time either. I guess it is time for some people to do some actual R and D......... |
#12 |
I don't know how without schematic. But I happen to like that UPS for my line sources. Maybe yours was more crappy.
It doesn't work well with amps though.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#13 | |
#14 |
Anyone
Do you have a suitable circuit for the oscillator preferably low distortion that i can use thanks |
#15 | |
diyAudio Senior Member
Time for some soul searching, perhaps? Cheers,
Frank |
#16 | |
amen...
Placebo medicine works best when the doctor believes in it too. Next best is when the doctor is good at pretending to believe in it.DF96 |
#17 | |
#18 |
If you guys don’t mind, I’ve a few things to say about UPS's that may be mildly related to audio.
Most affordable UPS systems have inverter outputs specified as a modified sine wave. Most of us would call this modified wave form a square wave, saw tooth or ramp wave. Butt loads of harmonics. You need to spend some serious cabbage to get something like a best or Leibert UPS that has a low distortion sine wave output. I think similar things can be inferred about the quality of the filtering and line conditioning of cheap vs. quality UPS. These cheap things work well for our PC's because the PC's have switching power supplies that don’t care too much about sine wave distortion. |
#19 | |
I wouldn't be using it, if it didn't improve the sound. Works very good with my DAC, I didn't notice much improvement with a transport and I didn't like it with Zen or GC amps.
#20 |
Peter
You may be absolutely right that your ups improves the sound, but admit it: it's a dead end. For anyone willing to experiment, a good start is a Wien-bridge oscillator as found in Art of Electronics or any other basic electronics text. Choose the circuit with a miniature lamp as amplitude stabilising element - it's usually better than the ones with fets. Use a decent opamp (5534 is perfect) and when setting the output amplitude check the distortion with one of the many freely-downloadable spectrum analysers and your computer sound card. The only real problem the Wien bridge has is the difficulty of varying the frequency - that's what prompted me to choose the AVR. cheers peter |
| cheap DIY PURE AC regenerator | audiojoy | Power Supplies | 46 | 9th October 2010 11:08 AM |
| Do i need to build main supply (240v) filter?Or build power distribution? | thomgun_lc | Chip Amps | 9 | 16th September 2005 10:52 AM |
| Gainclone as AC regenerator | MtBiker | Chip Amps | 10 | 29th April 2005 06:55 AM |
| 1-tube Regenerator | planet10 | Everything Else | 2 | 17th March 2005 03:22 PM |
| Page generated in 0.11945 seconds (81.16% PHP - 18.84% MySQL) with 11 queries |
