Old 6th January 2011, 03:10 PM   #1
Send a message via MSN to grievousangel
Default QSC RMX1450 blowing Ch. A fuse
Hello All,
I have a QSC RMX1450 that has a dead Ch A and a OK Ch B. Ch A blows the B+ fuse on start up ASAP! I can lift the Ch A B+ rail leads from the main PCB and it does not blow the fuse.
I am waiting on a 22A Powerstat (variac) that I won on eBay to come in, but I am not real sure how to use apply the variac to get a soft start and not blow the B+ fuse.
Suggestions needed.
thanks,
billy
Old 6th January 2011, 03:23 PM   #2
HighTec is offline HighTec  Croatia
HighTec's Avatar
Hm, what about fixing the dead channel first and then power up the whole unit?
Old 6th January 2011, 03:32 PM   #3
llwhtt is offline llwhtt  United States
If the Variac has a current meter you'll see the amp start to draw lots of current as soon as you start turning the Variac up. Normally as you start to turn the variac up you'll see a small current surge then it will subside as the filter capacitors charge up. Shorted output transistors most likely. If you look at the schematic you'll see the collectors are grounded and the emitters are connected to B+ rail. Once an output transistor shorts it's B+ to ground and blown fuses. The million dollar question is WHY?
Craig
QSC RMX1450 FAMILY ( long ) sakis Solid State 6 22nd February 2010 02:07 PM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Blowing B+ fuse trombone Tubes / Valves 5 1st July 2008 02:05 PM
Blowing my fuse (s) Jimlondon Chip Amps 7 7th March 2005 06:03 PM
Page generated in 0.07853 seconds (66.48% PHP - 33.52% MySQL) with 10 queries
