Old 6th January 2011, 07:55 AM   #1
Default Power transistors
Are these transistors any good? For example SymAsym, etc…
http://www.semelab-tt.com/pdf/bipola...20MG6331-R.pdf
http://www.semelab-tt.com/pdf/bipola...20MG9411-R.pdf
Old 6th January 2011, 09:47 AM   #2
AndrewT is online now AndrewT  Scotland
the spec reads as good.
SOA 3Adc @ 100Vce is indeed mighty.
I wouldn't class it as 60MHz fT more like 40 to 50MHz, comparable to other manufacturers.
Probably worth trying a complementary pair of samples and report to us and Semelab.
regards Andrew T.
Old 6th January 2011, 10:16 AM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
Pretty hefty BJT's. Competitive. A nice beefy driver stage might be in order to maximize potential for these.
All the trouble I've ever been in started out as fun......
Old 10th December 2011, 10:11 AM   #4
Does anyone have a SPICE model for the MG6331 transistor?
Old 12th December 2011, 01:30 AM   #5
djk is offline djk
djk's Avatar
SEMELAB|MG6331-R|TRANS,AUDIO,NPN,260V,18A,TO-3P | Newark.com
"SOA 3Adc @ 100Vce is indeed mighty."
SOA is only 1A at 100V.
http://www.farnell.com/datasheets/866305.pdf
Candidates for the Darwin Award should not read this author.
Old 12th December 2011, 01:54 AM   #6
mt490 is offline mt490  Australia
The specs for the semelab and magnatec brand transistors seem to be very different despite the similarities of the part numbers and parent company.
Old 12th December 2011, 02:30 AM   #7
djk is offline djk
djk's Avatar
This is the highest SOA device in plastic I have ever seen:
http://www.onsemi.com/pub_link/Colla...MJL21195-D.PDF
Old 12th December 2011, 09:24 AM   #8
Originally Posted by djk View Post
and the datasheet shows the knee in the SOA plot @ ~2.5A and 60Vce. giving 150W dissipation. Clearly not a 300W device.
regards Andrew T.
Old 12th December 2011, 11:31 AM   #9
Pingrs is offline Pingrs  United Kingdom
The OP’s data sheet (doc 9096) reads ~2.3A at 140V. The Farnell one (doc 8684) is odd- nine divisions/decade on the log/log graph? So which do you trust?
Brian.
Old 12th December 2011, 11:40 AM   #10
These are the most powerfull I have found in plastic, MG6333 and MG6332:
http://www.farnell.com/datasheets/866313.pdf
http://www.farnell.com/datasheets/866312.pdf
But the Cob is 800 pF!
Why are Power Transistors so slow? janneman Solid State 60 13th December 2010 12:29 PM
Fairchild power transistors glen65 Parts 5 13th December 2009 02:11 PM
Cyrus 1 power transistors Fleetwood Max Solid State 7 11th August 2009 12:57 AM
Mounting power transistors loovet Pass Labs 6 29th October 2007 09:53 PM
SGS power transistors hifiboy Solid State 0 4th October 2004 07:44 AM
Page generated in 0.10951 seconds (77.91% PHP - 22.09% MySQL) with 10 queries
