Are there significant benefits using a dual mono supply ?
If I have only a single transformer with single centre tapped secondary it would seem the only option is a single power supply for both channels based on a bridge rectifier and a filter section. What if I used two half-wave rectifiers, one for each channel. Only one channel is 'communicating' with the transformer at any one time since their filter capacitors are being charged at different times. Each rectifier 'sees' half the load - i.e. only one channel so even though the charge pulses are now half as often the ripple voltage is the same as it would be if there were a bridge rectifier feeding both channels together. Thoughts ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#2 |
Does not the power supply need the filter caps to be referenced to GND? Other than that, half wave is fine and dandy but you will have twice the charging current at half the frequency of the bridge and with larger ripple. After all, the load circuit sees as its power source the charged capacitors not so much the transformer. IMHO two seperate bridge rectifiers from the secondary and sets of filter caps (if bipolar supply is required) would be a better solution. If this is for a power amp circuit, half wave is not such a good idea.
All the trouble I've ever been in started out as fun...... |
| 3.5mm Stereo to Mono w/ Channel Switch? | thehallofshields | Parts | 2 | 11th October 2010 01:16 AM |
| Dual Mono vs Stereo Power Supply Question | bluegti | Chip Amps | 4 | 2nd January 2007 03:26 PM |
| PS for GG - look for better channel separation | senderj | Tubes / Valves | 13 | 28th June 2006 11:25 AM |
| mono center channel out to stereo | rjeffersondc | Tubes / Valves | 5 | 31st December 2005 09:35 AM |
| Fisher Stereo Separation question. | Thatch_Ear | Tubes / Valves | 1 | 29th May 2002 06:02 AM |
| Page generated in 0.06743 seconds (68.47% PHP - 31.53% MySQL) with 11 queries |
