SO heres the schemo for the amp i've had problems with:
http://i.imgur.com/3cMIs.jpg After that miniamp i decided to hook this up again but it still does the same thing. When i give it a signal it oscillates, when i take the signal off the oscillation stop. If i try to give it bias it first starts like interrupted oscillation, then as i get higher it goes into steady oscillation. It's based on one of quasi's designs. The drivers and bias transistor is BD139 and BD140, NOT 2N5551 and 2N5401. |
#2 |
Here's a good approach to stabilize the amp.
1. start with just one pair of output mosfets. They vary so much in threshold voltage, that the multiple outputs will have problems unless closely matched. 2. drop the power supply down to +/-25, so if something bad happens, it won't destroy the world. 3. remove C9 and C8...they can be bad news...they may make Q11 and Q10 oscillate all by themselves. 4. It's way over-kill, but change C6 to 1000 pF...remember, our goal is to get it stable, then we can make it good. That limits GBW to about 1/(2*pi*100*1e-9)=1.59 MHz. With your feedback factor of 1.2/(1.2+39), your 3 dB freq will be around 47 kHz...ok for a first test. 5. Make sure power supply bypasses near the gain stages include 0.1 uF caps with short leads from both rails to ground. 6. Adjust bias Vbe multiplier for something reasonable...maybe 100 mA in the output devices. 7. Don't push the amp too hard...there's only one set of output devices there in this test. 8. If it looks ok, e.g. no oscillation, you can start backing C6 down until you see oscillation when driven. 9. If it still oscillates with C6=1000 pF, and everything else is done right, then you have a local (e.g. not a loop) oscillation. Most likely cause is Q11 M3 loop. If your 4 Ohm resistor is non-inductive, there should be no problem. If your 4 ohm resistor is inductive, or if you remove the load, the Q11 M3 loop may oscillate. If so, you need zobel at output node...10 Ohms in series with 0.1 uF is a good place to start. Good luck |
#3 |
At 2x35V rails it runs just fine with no oscillations in sight. With 2x50V rails i never get above 12mA bias.
Without the caps on the drivers it oscillates even worse. The oscillation is only on the positive side which i find weird, from 0v to around 5-8v. |
#4 |
Tekko,
82pF cap on both drivers B-E terminals is wrong concept. The Position of such caps should be at B-C terminals of Drivers. Using BD139/140 at rails voltages more than +/-35VDC is again a blunder mistake because during full output voltage swing the VCE limits of drivers will get exceeded and they will blow in no time. Replace them with MJE340-350 Pairs. Hope this helps, K
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#5 |
The drivers dont blow, if i reconfigure it to that miniamp it works just fine.
And if i put those caps between BC or BE doesent seem to make any difference what so ever. |
#6 | |
Your quasi schematic has high drop voltages it is inefficient for high power (you have many parallel IRF, it must be high power). Also it need higher wattage transistor for its driver longevity not 2n5401 Last edited by ontoaba; 5th January 2011 at 11:08 AM. |
#7 |
SUCCESS!!!
I replaced the BD's with IRF540 and IRF9540 and now it works just fine!! Maybe those BD's are the problem. I'll order some MJE340's and MJE350's and see if those will work. Even these IRF's are cutting it a bit short on voltage, beeing 100v devices. |
#8 |
Heres a vid:
YouTube - High power Mosefet Amplifier |
| MiniWatt N3 problems, oscillation thumping and RF/motor problems. | Destroyer OS. | Tubes / Valves | 18 | 6th July 2010 12:14 AM |
| my little QUASI AMP | sekhar | Solid State | 7 | 1st May 2010 11:01 AM |
| ESP P3A oscillation problems | Tsuruya | Solid State | 26 | 14th August 2008 06:54 AM |
| Still some problems with Crescendo. Oscillation or what? | Eccu | Solid State | 47 | 6th March 2004 04:11 PM |
| Debugging Quasi amp | cm961 | Solid State | 7 | 3rd February 2004 11:54 PM |
| Page generated in 0.11812 seconds (81.13% PHP - 18.87% MySQL) with 10 queries |
