I want something simple that will give me 2x200W into 8ohm, i want to do SS. I also want something quite simple and as small as possible. I was thinking of the QUASI amp for beginners for the simplicity and high power.
Any suggestions? Edit- because of the design of the chassis i'm using it would be a lot more simple for me to stay away from TO-3, thats the only problem with that amp.
I thought about it once, but then thought again. |
#2 |
There are several choices, The DX blame series and ostripper's mongrel are two very good performers.
Then theres the designs by Apex audio which are also very good, but mainly designed for PA but are still suitable for home hifi. |
#3 |
Okay thanks, I have some PCBs for the DX blame but they only use one pair of output devices is it possible to add more for increased power?
#4 |
Do you really need 2x200 watts in 8 ohms ? Even on really inefficient speakers u'll be deaf long before you reach anywhere near this power.
Even my subwoofer is too loud to stand on a 100 watt amplifier. |
#5 |
The new DX boards can be built to the 'supercharged' spec with two pairs of output devices.
Rich |
#6 | |
I think I have used the old revision.
#7 |
You dont need more than 50-100 watts peak unless its like a club or disco where you need to overvoice people screaming and yelling.
#8 |
With a bit of wisdom you can use these boards you've got for the Supercharged version (*). You only need to find a way to settle the second output pair and respective resistors (both base and emitter ones). I've done!
Regards, Max.
We should not dwell on what we do not have, but, instead, be grateful for what we do have! |
#9 | |
I am becoming almost deaf listening to my original DX Blame ST in full power under 8 ohms load. No distortion, just pleasure! Cheers, Max.
#10 | |
If you ever want to "explore" just swap out a voltage stage , hear a "leach" or a "symasym" , "blameless" .. etc. ![]() The whole deal below fits in a shoebox with room to spare.. OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ Last edited by ostripper; 3rd January 2011 at 10:04 PM. |
| Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 | quality sound | Tubes / Valves | 0 | 9th May 2009 03:59 PM |
| Krell KSA 80 bias & dc offset check & adjust procedure | Clouseaupte | Solid State | 3 | 9th August 2007 09:39 AM |
| DIY-AMP <ZAS> Low THD & IM high bandwith | murphy | Solid State | 18 | 30th December 2005 10:28 AM |
| Page generated in 0.09844 seconds (81.80% PHP - 18.20% MySQL) with 11 queries |
