Hi guys,
i an currently building holton AV400 amp. with 2x50 v 1KVA transformer my question is can i use IRF640/IRF9640 instead of IRFP240/IRFP9240 ..? |
#2 |
use IRFP240/IRFP9240 is ok minimam 4pair for good results
#3 |
ok but what about using IRF640/IRF9640 instead of IRFP240/IRFP9240..??!!
#4 |
Yes, you can use them but they have a maximum power dissipation around 125w so you'll need to use at least 6-7 pairs per channel. Especially if you wanna drive loads under 8 ohms.
#5 |
I found irfp240/9240 to be more available.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#6 |
You're building a high power amp. Don't try to skimp on the cost, build it as the designer intended, unless you want it to blow up in your face.
Look at the difference between the two devices. IRFP240's are capable of 20A and dissipating 150W in their TO-247 casings. The IRF640 does 18A, but it is a TO-220 case that will only dissipate 125W. You will be reducing the dissipation of the amp to the point where it will blow up. If you use more devices, then you are making a harder load to drive, which will result in instability. Last edited by jaycee; 2nd January 2011 at 08:17 PM. |
#7 |
<<unless you want it to blow up in your face.>> u r right jaycee,i think i missed this point ..
#8 | |
It depends on the end use and how much money you want to spend. Vertical OPS = GOBS of power (PA use)... lateral OPS= nicer sound , less power - simpler biasing. OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#9 |
Hi
You can find IRFP240 and IRFP9240 at DigiKey or Mouser but they are expensive there. Where are you from? I could help you out. I bought 100 each for my project and could sell you 2x4 matched devices. Regards, Lee |
#10 | |
i am from egypt too far from u but any way thnx 4 trying 2 help me.and what`s the best way to match these mosfets ?? regards, shady |
| A.Holton AV400 using irfp or Quasi mosfet amplifier ? | medogrizli | Solid State | 49 | 5th November 2011 11:04 PM |
| FS: AV400 Anthony Holton Aussie Amps | HipoFutura | Swap Meet | 5 | 14th July 2011 04:56 AM |
| A. Holton AV400 power amplifier | Stanley Drake | Solid State | 47 | 18th September 2008 09:44 PM |
| old Holton schematics | sunrise | Solid State | 5 | 1st December 2005 08:53 PM |
| Anthony Holton | nikonfanatic | Solid State | 6 | 15th August 2003 12:54 PM |
| Page generated in 0.10141 seconds (80.79% PHP - 19.21% MySQL) with 11 queries |
