Old 2nd January 2011, 10:23 AM   #1
Default Is this a bad scheme
Some guys told me this is a poor scheme and I also want your opinion.
Old 2nd January 2011, 11:14 AM   #2
wahab is offline wahab  Algeria
All the transistors have far lower Vce than required,
only the 140 V VCE output pair may survive the voltage,
BUT not the output power if ever it is used at full power
on a 4R load, or even unloaded, as the VBE multiplier
voltage drop is set with a fixed resistance divider which
is unrealistic given the transisors caracteristics dispersions..
Old 2nd January 2011, 11:14 AM   #3
jaycee is offline jaycee  United Kingdom
two pairs of MJ15003/4 on 70V power supplies is guaranteed to blow up when pushed hard.
All of the other transistors, BC557, BD139/140, BD243C/244C are also not capable of working on a total supply of 140V.
The circuit would work if you use say 35v supplies, but then you would not get 500W.
I wouldn't build it.
Old 2nd January 2011, 04:38 PM   #4
nigelwright7557's Avatar
I would have added a current mirror to the LTP.
Use MPSA42 and MPSA82 transistors as these can stand 150V easily.
I also would have added a safely wired pot to the Vbe multiplier.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 2nd January 2011, 07:56 PM   #5
Better to find a design already made for it, than try to modify one that isnt
Besides, 500W into 8 ohms is not really DIY - you will pay more to build it than you will to buy it.
Old 3rd January 2011, 10:04 AM   #6
Besides, with 70v rails you won't get much over 260 W RMS. (into 8R)
Old 3rd January 2011, 11:06 AM   #7
AndrewT is online now AndrewT  Scotland
we know you have a link to Romania and that this is your second post.
We have no idea what skills and build resources you have.
regards Andrew T.
choose the scheme superamplifier Class D 0 3rd July 2010 11:09 AM
Grounding scheme Sandor Construction Tips 12 9th June 2010 09:59 PM
Can this scheme works like this? Pigy Solid State 5 7th April 2010 08:32 PM
Here is my scheme... StalfoS Chip Amps 2 15th December 2006 09:09 AM
Page generated in 0.07068 seconds (82.65% PHP - 17.35% MySQL) with 11 queries
