Old 1st January 2011, 09:46 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default Thoughts on the velleman K8060?
Just wondered what people thought of this amp, I have built on once but broke it and never got to listen to it. They are cheap and are good quality but are they that good?
Velleman nv
I belive this is the schematic:
Boscoe
I thought about it once, but then thought again.
Old 2nd January 2011, 12:15 AM   #2
ostripper's Avatar
Not really , no current sources , low PSRR. Darlington OPS shunted by 680pF ... questionable stability. A similar amp with a current source and a true 2 stage emitter follower output scheme would be miles ahead in durability and sound quality. (below) is a similar but much more refined amp , it's sonics would overwhelm the velleman by a VERY wide margin at the cost of 3-4 more devices (cheap). The Velleman is more of a "student" amp , not really Hi-Fi .
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 2nd January 2011, 09:31 AM   #3
jaycee is offline jaycee  United Kingdom
It's a typical low cost kit amp, using cheap darlington outputs. It'll work - thats about the best you can say about it.
Old 2nd January 2011, 10:40 AM   #4
It's about the same circuit as a circuit from an 80's elektor catalogue.
Old 2nd January 2011, 11:51 AM   #5
meanman1964's Avatar
read this problem: project vellman!!
Old 2nd January 2011, 11:59 AM   #6
The person in that thread was trying to run the amp from higher supply voltages. on 35V supplies (using a 2x25v transformer) this circuit is OK - this is typical supply voltage, while Velleman show 40V supplies this would be the unloaded voltage, and will soon sag under load.
Velleman K8060 how good is it? Boscoe Chip Amps 0 16th July 2010 03:16 PM
velleman K8060 Harry Fisher Solid State 7 7th August 2009 02:31 PM
FS or trade: Velleman K8060 Power Amp kits Jan Dupont Swap Meet 7 29th November 2007 03:08 AM
Anyone know anything about the Velleman K8060 el-cheapo 100w amp? Spasticteapot Solid State 1 7th November 2006 01:42 AM
For Sale Heatsinks for Velleman Amplifer Kit K8060 primalsea Swap Meet 1 17th November 2005 06:14 PM
Page generated in 0.09468 seconds (74.14% PHP - 25.86% MySQL) with 11 queries
