Simple modification of Roksan Caspian
Old 20th July 2003, 09:53 PM   #1
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Cool Simple modification of Roksan Caspian
Hi everyone, this is probably one for novice modders, like myself.
I decided to try wiring in bypass/additional caps in my amplifier's PSU (Roksan Caspian integrated). These caps were mostly spare/used and are:
-22nf/400v film x2
-8.2uf/400v metal film MKP x2
-180uf/200v x2
-330uf/200v x2
-470uf/200v x2
10 caps in all, about 2,000uf to add to the existing 13,600uf.
The sound:
First impressions are of a cleaner, more sterile sound, uninvolving but powerful.
After some hours of play the sound has warmed up a lot and has more solid and controlled bass than ever before.
Overall, [probably] positive, and free! (because the caps weren't otherwise used)
I am going to try adding 4x 10,000uf to really beef it up, and we'll see what that does for the bass...
-Simon
Old 20th July 2003, 10:01 PM   #2
SimontY's Avatar
Some pictures to go with that description....
Here is the amp in question.
Old 20th July 2003, 10:07 PM   #3
SimontY's Avatar
Here is a poor pic of the unmodded internals, you can see the two 6,800uf 50v Aerovox reservoir caps.
Old 20th July 2003, 10:09 PM   #4
SimontY's Avatar
Here is the back of the main pcb, this wasn't much fun to remove, and I really am surprised and pleased the thing still works!
Old 20th July 2003, 10:15 PM   #5
SimontY's Avatar
I used some Shark (or is it Sharc?) 10ga. speaker cable to connect the new caps to the back of the original ones, all the little strands made it a real nightmare job. Oh, that and me being crap at soldering
Old 20th July 2003, 10:22 PM   #6
SimontY's Avatar
Testing for explosions etc. with the MKP film caps. - bypassing with these seemed to be a big improvement in itself actually, even just with the leads shoved in the wire...
Old 20th July 2003, 10:28 PM   #7
SimontY's Avatar
Testing with the first electrolytic cap. I put newspapers over the open amp and ducked down when turning it on, I get so scared of stuff blowing up or electrocuting me! I wired the caps in parallel with the original caps btw, one of each type per side. I must say, the reservoir caps seem to be wired in a funny way, it makes no sense to me! The + side of one is wired to the common ground - maybe someone technical can explain this phenomenon...
Old 20th July 2003, 10:31 PM   #8
SimontY's Avatar
Here are the five 'new' caps on one side.
Old 20th July 2003, 10:36 PM   #9
SimontY's Avatar
Here is the lot completed, the caps are glue-gunned on with the loc-tite glue gun seen in the bg. I apologise for the file size for those with old, analogue modems, and I hope at least one person gains a modicum of happiness from seeing this basic mod
-Simon
Old 20th July 2003, 10:51 PM   #10
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
I'd be very surprised if any of these mods improved the sound at all. What a waste of pictures.
Simple modification of Roksan CaspianHide this!Advertise here!
A simple Marantz CD42/52/72 modification SSassen Digital Source 15 2nd September 2008 09:27 PM
Roksan Caspian Power Amp Schematics Jorgitox Solid State 0 8th January 2008 11:56 AM
Roksan Schematics? Thiago Vianna Solid State 3 29th October 2007 10:41 PM
ROKSAN DA-1 Problem fosforo Digital Source 0 27th March 2007 08:47 AM
Roksan tonearm Delboy Analogue Source 4 20th May 2003 03:26 PM
