Old 27th December 2010, 08:51 PM   #1
Unhappy Problems with speaker protection kit
Hi there,
I recently bought a speaker protection kit to add to my power amp but I am having a bit of a problem getting it to work properly, so was wondering if anyone here who understands electronics a bit better than me can help me out here...
The kit receives power from the amp and the AC sense fine and after 5 seconds of power, the relay turns on with a click, but for some reason there is no sound coming out of the speaker where I have the positive side of the speaker wire connected to the outside lug and the wire from the amp to the middle lug and the negative to the left lug (as well as the left speaker output)
The speaker runs fine if i bypass the kit but doesn't turn on when connected to the relay. I am just wondering is this because I am only using one channel of the stereo kit and so need to either bridge the other side or should that not matter?
Is this kit running in mute mode because only one speaker is hooked up?
Hopefully someone who can read schematics a bit better than me can work this out for me.
Thanks a lot
Andrew
Old 27th December 2010, 09:18 PM   #2
Greg Erskine's Avatar
No and no. It should work fine for one channel.
Check the contacts are opening and closing with a multimeter.
Although it sounds like you have connected the input and speaker correctly (for R) I would guess there is a problem here. That is all that can be wrong if the relay is working.
Try the opposite side.
regards
Greg Erskine
Old 27th December 2010, 09:44 PM   #3
Thanks for the idea, I plugged the wires into the other channel and it works fine
So I guess I must have a faulty part on the original channel (R)... oh well, as long as one channel works is all that i need...
Thanks,
Andrew
Old 28th December 2010, 12:49 AM   #4
jaycee is offline jaycee  United Kingdom
If you hear the relay click, and the other channel works fine, it is more likely that the relay itself has a bad contact.
Jims Audio - 30A Speaker Protection Kit FlyAndy Solid State 16 14th January 2012 01:23 PM
Help with speaker protection kit julcat Solid State 3 21st January 2010 01:55 AM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
HELP with kit: speaker protection and muting paulspencer Everything Else 0 7th September 2005 01:57 PM
Loudspeaker protection kit Vivek Multi-Way 98 5th September 2003 07:49 AM
Page generated in 0.06834 seconds (84.26% PHP - 15.74% MySQL) with 11 queries
