... and 280Watt(RMS) class AB into 4Ohm.
That’s it, this thing sits on my desk for about 30 years now, it may even be the first power HexFet amplifier in the world (for as far that I know), the first version was built about 27 years ago and was designed for IRF HexFet’s (the IRF140). At that time I was an engineer for a Dutch company that was the representative for IR (International Rectifier), the components where very new, the first ever HexFet was being sold in (or around) 1978. But being working for IR gave me access to early samples. This thing is different, it runs from one supply voltage, + and – 45Volt, and the output goes rail to rail, actually +42 to -42Volt. The topology of the amplifier is differs to any I have ever seen, but I am not 100 percent sure it is my design/invention. Naturally part of the design is conventional and re-usages earlier design principles. That first version has been my main amplifier for years, it hummed and hissed all the time, but it sounded very ok and it was the only amplifier that I owned. Last month I did rediscover the build version (later I will post some pictures) and started to dig up those old designs. The next thing that I did was; put the design into a spice program (I used LTspice) and run a few simulations, and it worked. Now two weeks later I have the design fully optimized en modernized, all components are replaced with modern/current versions. No humming and hissing any more. Have a look at the attached picture, it shows the amplifier running (simulated) at 20Volts into 8Ohm at a input frequency of 20Khz, the first significant, and last, harmonic is 30Khz at about -90dB. The graph also shows some spikes at 200/300Khz but I do not think these are significant (any way it’s version beta 0.9). Let me know what you think about this, and should I show it or sell it Regards, Frans de Wit. Last edited by FdW; 27th December 2010 at 03:45 PM. |
#2 |
Neat!!!!
Looking forward to seeing the Photos and schematic. |
#3 |
quote 155Watt semi-class A into 8Ohm .........and the output goes rail to rail, actually +42 to -42Volt
150watt with 40V rails ? I thought it would be less |
#4 |
tinitus,
The rail is 45Volt, and (42*42/8)/sqrt(2) = 155 Regards, Frans. |
#5 |
I don't think hes gonna publish the schematic since he placed the graphs on top of the circuit.
I'd like to know what settings he used for the fft. |
#6 |
Tekko, you can see the settings on the right side of the graph, and I am rely seriously thinking about publishing the schematic, but give me some time to think about it, and maybe someone is going to give me an offer of some kind...
Regards, Frans. P.s. one can always hope .param a 10K ; step param a list 1K 10K ; Fin .param b 0.98 ; Vin for 20Volt out .tran 0 6ms 1ms 10n Last edited by FdW; 27th December 2010 at 04:12 PM. |
#7 |
Tekko, and if you see anything wrong with the settings I will rerun using different ones (as I indicated, it is the first time I am seriously using a spice tool (of any kind)).
#8 |
Here is another picture, the amplifier is running into clipping at 42Volt delivering about 155Watt RMS into 8Ohm the output stage is never out of current (does not enter class AB). The first harmonic 20Khz is at -60dB. Pretty cool for an amp running into clipping
Regards, Frans. |
#9 |
One more picture 42Volt 155Watt, this is showing the source current, and you can see that the amplifier is at clipping point, the positive side just running out of current… (red and blue traces)
Regards, Frans |
#10 |
First of all, let me add the original (1982/83 or there about) schema (do not try to build this, it is rubbish
| 8ohm resistor in series with 8ohm speakers for a 16ohm OT? | Reidy- | Tubes / Valves | 8 | 10th January 2010 11:25 PM |
| 3rd Order Harmonic Distortion in my in-room measurements | wigginjs | Multi-Way | 7 | 23rd November 2009 06:21 PM |
| Small Class-D chip wanted. ~25W/8Ohm | rkn | Class D | 7 | 12th March 2009 01:44 AM |
| Aleph-2 50W@8ohm 20KHz | emb51 | Pass Labs | 8 | 8th September 2006 04:10 PM |
| Page generated in 0.12063 seconds (84.37% PHP - 15.63% MySQL) with 11 queries |
