Quasi complementary outputs in a full complementary circuit
Old 26th December 2010, 07:12 PM   #1
xeclipse is offline xeclipse  Kenya
Location: Where the world's best tea come from:Kericho Kenya
Default Quasi complementary outputs in a full complementary circuit
Hi guys,
Am rebuilding an amp which was originally full complementary.Am through with a pair of 2sa1943/2sc5200 with a supply of +/-50v.I intend to use the amp on a 4 ohm load so i needed to add another pair to the output stage.The (only)seller tells me that she wouldn't be stocking any of that stuff in small silicon packs this coming year.She has run out of genuine 2sa1943's,just the 5200's.Am on student budget and can't buy them online(who knows?they might as well be fake!).I have a crazy idea about my situation:i did something that none of you would do.I 'fixed' the trannys onto the heatsink with epoxy since i couldn't get thermal grease.Am not about to hammer a 1943 out so i was thinking maybe i could have the first pair in full complementary and the second pair in quasi complementary...like in ampslab's c200.1 quasi complementary.What do you think?Am just doing this out of necessity and don't know if it can work,can it?
If not,what changes do i need to make on the circuit to make it a quasi complementary amp?
Regards.
if there are no sparks,it probably doesn't work!
Old 27th December 2010, 12:34 AM   #2
ostripper is offline ostripper  United States
ostripper's Avatar
"B" (attachment 2 - quasi) is directly "swappable" with "A" (attachment 1 - standard). Only built 1 quasi ...merely as a exercise , it worked. No need to here in "semi infested" mouser land , lots of pnp's available .
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 27th December 2010, 04:25 AM   #3
Whats up with the red arrows?
Old 27th December 2010, 04:33 AM   #4
stratus46 is online now stratus46  United States
Have you checked the power bandwidth? 2N3773s are mud slow transistors.
G
Old 27th December 2010, 07:16 AM   #5
ostripper's Avatar
That what you have to change/add , if you started out with a standard EF2 ... you didn't specify your original design.
#1 - this is just audio , we aren't transmitting AM band .. #2 -I don't use those Just an example #3 - ya mean a builder would have to wait till the new year to hear the first note out of his new amp??
OS
Old 27th December 2010, 07:42 AM   #6
The original design look exactly like attachment 1 with a 220 ohm resistor in place of the 100 ohm R89.
How will it affect the performance if i solder the drivers' emitters resistors to the feedback instead of the original 220ohm resistor across the emitters?
Old 27th December 2010, 08:24 AM   #7
ostripper's Avatar
Well , the drivers won't be running class A like a EF2 does. Performance should be on par with a fully complimentary OPS. For a closer match in operating point (voltages), 3- 56-68R resistors(instead of the 39R's) would be a close match for your present 220R Re driver stage. This means your Vbe (Bias adjust) would still be in the proper range. Start with just 1 pair outputs to perfect the "swap".
OS
Old 28th December 2010, 08:22 AM   #8
Thanks Ostripper.
I hope you understand this idea i have and please let me know if it can work.
I'll use attachment 2 as an example. The first pair being full complementary,the base of the 1943 is soldered to the emittes of the driver(15031).The second pair being quasi complementary,the base of the 5200 is soldered to the collector of the driver.
What do you think? Can it work without a significant rise in distortion?
Regards.
Old 28th December 2010, 08:28 AM   #9
ostripper's Avatar
Thanks Ostripper.
Regards.
No - no , NO... don't mix the 2 topologies. Either FULL quasi or full complimentary. (All 5200's)
OS
Old 29th December 2010, 12:52 PM   #10
Thanks!
In attachment 2,what is the use of R20?I've seen many designs without it.
Quasi complementary outputs in a full complementary circuitHide this!Advertise here!
Another quasi-complementary design quasi Solid State 673 23rd June 2017 06:43 PM
Quasi complementary outputs in a full complementary circuit xeclipse Solid State 0 26th December 2010 07:08 PM
quasi-complementary output Vlad Pass Labs 4 13th April 2010 12:07 PM
Quasi or full complementary. pro Solid State 7 14th September 2004 09:26 PM
