Stereo amplifier sqeals at idle, distorts on one channel?
Old 21st December 2010, 09:20 PM   #1
nac134 is offline nac134  Canada
Default Stereo amplifier sqeals at idle, distorts on one channel?
I have a pair of Luzman M120a stereo amps that I run as dual bridged monos. The Left channel on one of them has started to emit a mild squealing sound, even at idle, and even if no source is connected. It also sounds very distorted when I play music through it.
I pulled a bunch of transistors off of the input stage, and tested them - all fine. I put them back and the problem went away for a couple days, then suddenly came back. Does anybody have an idea what might be causing this?
Old 21st December 2010, 09:27 PM   #2
jaycee is offline jaycee  United Kingdom
Squealing is oscillation. This is probably a sign the units need servicing for their age, probably needing complete replacement of all electrolytic capacitors.
Old 21st December 2010, 09:44 PM   #3
I should have mentioned that the caps were replaced about a year ago. I have 4 channels all together in 2 amps, but only one is doing it. Should I be looking for a faulty replacement cap?
Old 21st December 2010, 10:55 PM   #4
DF96 is offline DF96  England
A compensation capacitor gone open circuit?
Old 21st December 2010, 11:00 PM   #5
Im sensing a "capacitor" theme here. Can you test caps without taking them off the board?
Old 21st December 2010, 11:21 PM   #6
Not easily. You could perhaps check a compensation cap by temporarily adding an extra one in parallel - about the same value or a little smaller. If this solves the problem then swap the cap for the correct value. You would need a circuit diagram and the ability to read it. Typically there will be Cdom across the VAS stage, and possibly a lead-lag network at the input stage collector and a Zobel network at the output.
Old 21st December 2010, 11:49 PM   #7
Thanks for your help. I do have the schematic and service manual. However, my knowledge of schematics is rudimentary. For example, I don't know what a Cdom is. It will probably be easiest for me to just get out the soldering iron and start pulling of caps and testing them.
Old 21st December 2010, 11:50 PM   #8
Actually got a 3rd degree burn last week doing that with the transistors.
Old 22nd December 2010, 12:00 AM   #9
Tekko is offline Tekko
Banned
Cdom is a capacitor that goes between base and emmitter of the VAS (Voltage Amplification Stage)
Old 22nd December 2010, 08:52 AM   #10
Elvee is offline Elvee  Belgium
Elvee's Avatar
Are there any switches, connectors or any other form of contact in the path?
Stereo amplifier sqeals at idle, distorts on one channel?Hide this!Advertise here!
hight idle current HARMAN amplifier ericb Solid State 0 2nd March 2008 05:09 AM
Automatic idle current amplifier senicz Chip Amps 3 1st March 2006 02:17 AM
Right Channel not working on Stereo reciever nicku1302 Parts 1 29th November 2005 03:32 AM
question for those using subs with 2 channel stereo Jim85IROC Subwoofers 15 26th March 2004 03:38 PM
LA4743B Car stereo BTL 4-channel (45 W x 4) power amplifier IC emuman100 Chip Amps 2 15th March 2004 07:21 AM
