Anyone have a simple test circuit?
I have a bunch of BC556B (pnp) and want to select them for an LTP stage. |
#3 |
I don't bother with matching, the difference is so little its in the region of 0.0001% THD difference or less in matched or unmatched.
#4 |
Tekko,
You need to match the transistors to minimize the offset voltage. Yes, unmatched device will produce very little distortion in a closed loop amp, but that's not the reason for matching. Rick |
#5 |
That is matching for Hfe, he asked for a circuit to measure noise. I assume he wants the 'quietest' specimens for his LTP.
#6 |
Even offset difference will be so small that matching is a waste of time, atleast in a hobby project.
However if it was a commercial product like a high precision instrumentation amplifier, then matching is highest priority. |
#7 |
#8 |
Something like this?
#9 |
RJM1, how do i work out the component values for a +/-12v supply and 1ma thro Q1?
what R values for the opamp? use a scope on the output? thanks. |
#10 |
I really appeciate the idea. In the short time that I am readig this forum, I have seen that much concern is taken for THD, then less for offset, but very few for noise. If I remember well the noise should be indeed of concern specially with FET transistors that should (correct me if I am wrong) be affected of 1/f noise. Also I never have seen explicitely (maybe it was done anyway) dimensioning resistors for noise avoiding. I mean trading a higher dissipation with a smaller R. This is done always when you design measurement instruments. Sometimes I had also the impression ( i should research on that) that sophisticated schematics (i.e. cascoded and double CCSs, especially Zener ones) besides of the linearity (read THD) advantages may bring in additional noise. Very interesting post
effebi |
| PGA 2311 Test Circuit | HarryK | Chip Amps | 13 | 15th March 2011 09:42 AM |
| Tube aging, in-circuit test? | Skorpio | Tubes / Valves | 5 | 27th September 2010 09:11 PM |
| How to test noise level of PSU? | Sunsun22 | Power Supplies | 2 | 10th August 2006 01:48 AM |
| Tube tester and noise test | Jeffy74 | Tubes / Valves | 1 | 7th March 2004 06:49 PM |
| Toshiba JFETs BJTs Sanken BJTs | Praise! | Swap Meet | 5 | 14th February 2004 06:45 AM |
| Page generated in 0.45851 seconds (25.50% PHP - 74.50% MySQL) with 11 queries |
