Old 16th December 2010, 03:35 PM   #1
Default Class A Listening fatigue
I have made a Class A amp using single mosfet and others using BJT or a Darlington for the only active component.
While it sounds deep and rich...great imaging, transparency and detail...I can't listen long without experiencing listening fatigue...I am not playing at loud volumes. I experience this both when the highs are overpowered by the lows and when the highs are a little bright.
I have been unorthodox in using a switching power supply that switches at a rate well into the GHZ.
Could the switching power supply cause the fatigue?...(the sound of tv's and computer monitors used to drive me crazy)
Or would second order Harmonics play a role in this?
Or both?
I got the THD down to .3% on the simulator ( not the most accurate) and I hear very little distortion...but the ear is not the most accurate for THD...just the most accurate for what sounds right.
Old 16th December 2010, 04:02 PM   #2
tinitus is offline tinitus  Europe
I would like to see your speakers
Old 16th December 2010, 04:08 PM   #3
AndrewT is online now AndrewT  Scotland
Default ClassA listening fatigue and switching PSU
this does not sound like a nice combination.
Let's see the schematics and the build.
regards Andrew T.
Old 16th December 2010, 04:14 PM   #4
Root2 is offline Root2  United Kingdom
Root2's Avatar
Or both?
GHz SMPSU I would love to see that sounds like fun.
Old 16th December 2010, 04:24 PM   #5
WuYit is offline WuYit  Sweden
Banned
the cure is a decent (big & bulky) power supply.
Old 16th December 2010, 05:18 PM   #6
Root2's Avatar
Regulated or just Bulk caps, and how fast if regulated should the feedback control be for the PSU? any thoughts?
Old 16th December 2010, 06:21 PM   #7
Banned
Root2,
just bulk caps will not suffice, either choke regulation or something like this:
Old 16th December 2010, 06:48 PM   #8
Maybe too much odd order distortion?
The second order distortion should not harm sonically, but 3rd, 5th a.s.o. might and even low values are audible.
Could be the price for a very simple amp.
Old 16th December 2010, 07:21 PM   #9
I seriously doubt that listening fatigue is down to the amp itself, unless it oscillates or produces extreme amounts of overtones. Listening fatigue in my experience is usually what happens if you listen to a non flat frequency respons, which is usually caused by room influence, or the speakers themselves. Especially, if you have a peak in the region where the human ear is most sensivite, 2-5 kHz, you are very likely to find it fatiguing, even if this initially might be experienced as "great imaging" and detail.
Just my 5 cents worth.......
Old 16th December 2010, 08:19 PM   #10
Bigun is offline Bigun  Canada
Bigun's Avatar
Could it be the source and not the amp ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
What causes listening "fatigue"? critofur Multi-Way 175 10th February 2010 10:36 PM
listening fatigue of Proac 2.5 clone kevinkuang Multi-Way 2 9th April 2005 04:42 PM
Page generated in 0.15182 seconds (73.19% PHP - 26.81% MySQL) with 11 queries
