Hi buddies
If i do something wrong please tell me on time |
#2 |
#3 |
Take a look here :::Borina Amaterska Svastara::: the Legend stage master is a good one.
I also have one but send me private mail for that Last edited by meanman1964; 2nd January 2011 at 08:41 AM. |
#4 |
Here is the layout
#5 |
Here is a popular schematic with complementary power transistors
#6 |
Also very nice
#7 |
Thanks to two colleagues but i realise that scheme from meanman1964 is better and much easier
1. Does this scheme surely works ? 2. What transformer i need to get the full power from this amplifier ? 3. How much maximum real power can i get from this amplifier (RMS) ? Last edited by DANIEL SPASOVSKI; 10th January 2011 at 03:17 PM. |
#8 |
It will provide your 400W RMS into 8 ohms but you will need a lot of FETs and a LARGE heatsink - it will get HOT.
For 95V supplies you would need a transformer with 70V AC secondaries.. it would have to be large, 1000VA at least. You would need a lot of power supply capacitance also. These amps are not simple, cheap or safe to DIY - you really must know what you are doing - the power supply voltages alone can kill you |
#9 |
If you don't know how to arrive at these answers then I suggest this is not a project for you at your current level of expertise.
regards Andrew T. |
#10 |
Agreed. Class AB is not really suitable for these power levels anyway. Class G/H is not simple to build either. If you really require this sort of power level, you are far better buying a commercially made amplifier. If you buy a second hand one in good working order, it will be cheaper than anything you can DIY.
| BGR Mosfet 400w Amplifier KIT | dmcabs | Solid State | 11 | 23rd March 2011 06:56 AM |
| NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale | magnum_1 | Swap Meet | 16 | 13th June 2009 03:59 PM |
| Is this worth building? 400W MOSFET | PetarLD | Solid State | 7 | 14th July 2004 03:19 AM |
| a MOSFET amp scheme | jamesjung21 | Solid State | 2 | 13th January 2004 01:00 AM |
| Page generated in 0.08905 seconds (86.35% PHP - 13.65% MySQL) with 11 queries |
